Old 02-24-2019, 10:27 PM
rvdave rvdave is offline
Default Hot weather ground operations
From Michigan but currently flying in Florida and noticing after landing in hot temps and especially after hot starts and taxiing I?m getting rough running that I haven?t noticed before since I?ve only been flying for a short while. Seems to me to be hot fuel since after airborne and normal airflow problem seems to go away. Is this common for hot weather ops and fuel injection?
Dave Ford
Cadillac, Mi
Old 02-24-2019, 10:39 PM
lr172 lr172 is offline
Pretty common with Bendix FI. Usually seen shortly after landing and more so after starting with a heat soak. Symptoms increase with the ambient temps in the summer wx. Seems some configurations fair better than others though.
Larry
Old 02-25-2019, 05:43 AM
Auburntsts's Avatar
I have the AFP FI system (FM 200) and haven't noticed the issue you are describing.
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
Old 02-25-2019, 08:23 AM
Phil's Avatar
Phil Phil is offline
Pretty common here in Texas. The taxi-in is noticeable after a few minutes on the ground. After it’s shut down and heat soaked, it’s even worse.
The AFP fuel bypass valve helps with the restarts and makes the stumble less noticeable. But on seriously hot days, it doesn’t always fix the stumble as there’s just too much heat for the small amount of fuel needed to idle.
Until a high volume of fuel runs through those lines and cools them down, the stumble persists during hot ground ops. Once the rpms come up and the fuel starts flowing in a higher volume, there’s enough thermal mass in the fuel to make the engine operate smoothly.
... then, of course, once you’re flying you’ve got the added cooling of the air on the lines.
What you describe is something we see here pretty frequently in our local -10 fleet.
Old 02-25-2019, 12:09 PM
jeffkersey's Avatar
jeffkersey jeffkersey is offline
Default Yes...
I whave see similar symptoms on my injected I0-360 when really hot...
Jeff Kersey
RV7A Purchased Flying
Dues paid
Old 02-25-2019, 12:11 PM
bruceh's Avatar
bruceh bruceh is offline
I've given up trying to idle my IO-320 at less than 1000 rpm when heat soaked.
It idles fine at lower RPM's when the engine isn't heated up.
Bruce Hill
2020 VAF donator
Old 02-26-2019, 11:46 AM
dmaib's Avatar
dmaib dmaib is offline
Very common on all the -10s I've flown here in FL. I almost always open my oil door after shutting down on a fuel stop or a lunch break to try and let some of that heat escape.
David Maib
RV-10 N380DM
New Smyrna Beach, FL
VAF Paid 1/21/2020
"In '69 I was 21, and I called the road my own"
Jackson Browne
Old 02-26-2019, 01:34 PM
snopercod's Avatar
snopercod snopercod is online now
Have you tried leaning?
(2020 dues paid)
Old 02-27-2019, 03:52 AM
It does seem to help a little with leaning but not to the point where it will run smoothly. I do have the purge valve and am experimenting with that to push cool fuel before taxi.
Dave Ford
Cadillac, Mi
Old 02-27-2019, 08:20 AM
painless painless is offline
Hot weather ops?? What?s that? (As I get ready to fire up the snowblower..... again!)
Jeff Orear
RV6A N782P
Peshtigo, WI
