Old 01-25-2019, 05:17 PM
kentlik's Avatar
kentlik kentlik is offline
Originally Posted by ClayR_9A View Post
I'd go with braided steel covered flex lines from TS Flightlines for the brake lines from the fuse to the calipers. Also the fuel lines from the tanks to the valve. And the fuel vent lines from the tank to connect to solid aluminum lines once they get inside the fuselage.
I've had to uninstall/reinstall my tanks so many times and flare fittings seem to get worse every time you remove/reinstall them. Also, any vibration eventually causes cracks at the flare if they aren't perfect.
This is good information, thank you.
I am going to go with flex for the brake lines to the caliper certainly. I am currently working on the fuel lines from the valve to a bulkhead fitting on the fuse and was considering flex from there to the fuel tank. Not sure that is a good or bad idea yet.
What I did want to say is that I ordered some fittings from Andair and they arrived in Portland OR. in less than two days!
That is FAST!
Kentlik
RV-7A in progress
http://www.imdb.com/name/nm0527486/?
Private pilot, ASEL!
EAA 105 Chapter 7S3
Bi-annual financial contributor
"The credit belongs to the man who is actually in the arena..." Teddy Roosevelt
Old 02-05-2019, 09:43 AM
kentlik's Avatar
Roger that. I think that is a good way to go.
Kentlik
RV-7A in progress
EAA 105 Chapter 7S3
Old 02-23-2019, 08:05 PM
kentlik's Avatar
Default Fuel lines
Got back to the fuel lines, need a return so I spent a lot of time researching
the best way to do it. At least I think it is currently.
I have some more pic's to take but it is cold out there...
Kentlik
RV-7A in progress
EAA 105 Chapter 7S3
Old 02-27-2019, 12:20 PM
kentlik's Avatar
Default bunch of 90? bends...
Start of fuel mockup on the bench. Kitchen remodel bench.
I looked at the standard Vans valve and it had 90? bends.
Now I worked for a time in fluids and controls at an engineering firm dealing with prototypes and we avoided 90? bends like the plague in pneumatic systems. Low pressure systems, 50-250psi. I am going to have to do some semi-scientific empirical testing on this to satisfy myself this is GTG as I don't have four different types of engineers to get free information from hahaha!
Good news is I can read!
Kentlik
RV-7A in progress
EAA 105 Chapter 7S3
Old 02-28-2019, 10:29 AM
BruceW BruceW is offline
Kentlik.
You have seen the stock RV-7 boost pump, check valve, filter contraption with all the plumbing? Looks like a thermal detonator. Lots of bends, and seems to work just fine.
Bend on.
(oh, dont forget to add the sleeve before you flare the end. Ask me how many time I know.)
Bruce W
RV-7 QB (500+ hours)
RV-14 in waiting
Elk Grove, CA
Old 02-28-2019, 11:16 AM
dtw_rv6 dtw_rv6 is offline
Can you punch holes in those side bulkheads and route through them?
Better is the enemy of good enough!
Don
Old 02-28-2019, 02:03 PM
Does take quite a bit of thought to get all of that stuff under the stock covers, ESPECIALLY with the NPT ports. Our way might not be the least expensive, but certainly the least headaches. BUNCHES of them flying without issue.
Tom
RV7A Tail Kit Completed, Fuse started-Pay as I go Plan, on hold while we develop new products for RV builders
Ridgeland, SC
Old 03-01-2019, 10:41 AM
kentlik's Avatar
Originally Posted by BruceW View Post
Kentlik.
Bend on.
Roger that, bending on...
Kentlik
RV-7A in progress
EAA 105 Chapter 7S3
Old 03-01-2019, 10:44 AM
kentlik's Avatar
Tom
Tom thank you!
You helped out with advice and pictures! I am just in a phase of spending money to realize this might not be the way to do it. Hahaha
Then end up buying your lines...
Kentlik
RV-7A in progress
EAA 105 Chapter 7S3
Old 03-04-2019, 02:33 PM
kentlik's Avatar
Default 90? Andair fittings
I ordered a few of these fittings from Andair to use in the fuel system design.
Kentlik
RV-7A in progress
EAA 105 Chapter 7S3
