Originally Posted by iamtheari
By foam, I just meant to replicate the process in page 35-09 steps 1 and 2 followed by page 35-22 step 2, where small foam blocks are used in a couple of larger gaps where the upper longerons meet the firewall and forward upper skin as backing for pro seal.
The gaps I am asking about here are where the lower longerons meet the firewall, side skin, and bottom skin. I'm wondering if I should plug the gap with foam blocks from the inside to form a backing for pro seal on the outside (firewall side).
As long as the foam is later removed, but I can't imagine holes large enough to need it. DanH has proven that you want nothing on the inside of the firewall.
Ray
