02-16-2019, 03:52 PM
Mythical Drawing 21
On the RV-8 Drawing OP-35, in the notes section, it says:
1. Refer to the following RV-7 Drawings for additional Information:
Cabin Heat & Manifold Pressure: OP-33
Control Cables: OP-26 & RV8-21
Oil System: OP-27
Further, on Drawing 48 (Cowling Installation) in the Cowling Attach Detail section, there is a callout for a gap in the hinges near the top, and says "LEAVE GAP SEE DWG 21".
Neither in my full set of plans, nor in the plans I got from Vans on a USB drive, can I find a DWG 21, or an OP-21.
Does this drawing actually exist?
~Chuck
DG-800S Sailplane
QB RV-8 -- Working on final wiring and the engine
84CX Reserved
02-17-2019, 09:22 AM
Very often it referes to a drawing that is not included, i ended up buying the USB with all the RV-8 related drawings from Van`s, very handy and for the cost of a Big mac
Dennis Isaksson
G?llivare, Sweden
Grew up with an RV-4, SE-XIO
Now: RV-8, Showplanes Fastback. #83218 Under construction, SE-XXO
Engine and avionic installation in progress
02-17-2019, 09:35 AM
Over the years, the drawings have been renumbered, and sometimes not all the cross references to a given number are found and changed. Likely you have the drawing, but it has a different number.
In my 2006/2007 drawing set for the RV-8, DWG 21 is titled "F-801, F-866 Bulkheads, and Longeron Bending Diagrams".
Find that title, and odds are good the info you are looking for will be there.
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 625
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Jan 2020
02-17-2019, 09:39 AM
RV-8 DWG 21 is one of the RV-8 drawings included in the plans package. It shows the 2-inch hinge gap at the top of the firewall and its measured position.
The title on the page is:
F-801 & F-866 BLKHDS.
LONGERON BENDING DIAGS.
The file name on the USB drive is 21_8.pdf
If you're missing your file on your USB drive for some reason, shoot me a PM.
Building RV-8A since Sept 2014 (N88VX reserved)
Aurora, OR (EAA Chapter 105)
02-17-2019, 11:42 PM
Found it
Thanks very much guys. I found the file on the USB drive. I had a searchable PDF of all the plans (or so I thought), but evidently, there are some plans on the chip that are not in that file.
~Chuck
DG-800S Sailplane
84CX Reserved
