Originally Posted by Dean Pichon
Hi Wyn,
I just installed the Dynon AoA probe in my completed RV-4 in November. I already had a D10A installed so the display component was a none issue.
I had to remove the tank to run the 2nd pitot line to the Dynon instrument. With the Dynon probe, it is necessary to drill and tap the mast portion to attach to the mounting base installed in a flying aircraft.
In addition, I had to run a wire from the Dynon unit to my intercom and install a potentiometer in the panel to allow me to adjust volume of the audio signals in my headset. The Dynon instructions are pretty good.
I'm still learning how to best use it, but I believe it will be a great addition to my aircraft.
Good luck,
Did you replace the stock Van's pitot tube with the Dynon AOA pitot tube? That's what I want to do in my RV-8. It has the stock Van's pitot tube and need to know if the mount will work or if I have to buy a new mount.
I want to buy this style AOA pitot tube one from Dynon as it looks like the one I have now
https://www.dynonavionics.com/includ...Dimensions.pdf
but if I have to replace the mount I might go with the L style which doesn't extend so low under the wing.
RV-8 N52VM: OnSpeed Gen2 AOA-3D, Dynon D-180, Autopilot, Titan 0-360A1A, Hartzell C/S, INS-429 IFR & GPS496, WingX & Stratux for backup & ADS-B IN. Enjoying life while building an airpark with FREE campsite for pilots www.facebook.com/VacaMooAirport/
Exempt by 3 out of the 10 ways but I still donated.
