Old 02-05-2019, 06:38 PM
dbaflyer dbaflyer is offline
Default braided grounding strap isolation
I am working to put one of these from my engine to firewall FOT stud. Does the braided strap have to be isolated from touching anything between the two mounting points? My path from engine mount point to FOT is somewhat difficult from having a completely clear path. Is it OK to touch at least the engine mount?
Denis Sailer - Eastern Iowa
RV9A builder - Phase 2 (42 hours)
RV-9
Old 02-05-2019, 07:52 PM
DRMA DRMA is offline
Shouldn't be a problem so long as the grounds are solid at each end. So long as there is no potential (voltage) between the points contacted (e.g. no resistance between them along the ground strap) there should be no issues. In fact, on the RV-10 Van's recommended ground strap connection points are between the engine and tabs provided on the engine mount for that purpose.
Dave Macdonald
RV-10 First Flight April 1, 2020. Currently in Phase 1
2020 VAF Dues Paid
Old 02-05-2019, 08:34 PM
RV7A Flyer's Avatar
Just be aware of the potential for the strap to abrade whatever it's touching. I'd rather see a clear path with plenty of room around it. The engine moves a lot on startup/shutdown, plus the vibrations during normal operations.
You don't want to set up a situation where it will damage something like the mount.
2019 Dues paid!
Old 02-06-2019, 10:54 AM
Carl Froehlich's Avatar
There is no requirement to use a braided ground strap, and some reasons not to.
I use the same gauge welding cable (#2) to ground the engine that runs power to the starter motor. I ground the engine on the nice ground lug on the back of the starter - that is what needs the good ground in the first place.
Carl
Old 02-06-2019, 11:25 AM
YvesCH YvesCH is offline
I also used a #2 welding cable to the starter lug. And another one to the vacuum studs..
Yves - Basel, Switzerland
RV-8 #83458 HB-YUA
Donation 2019 done
Old 02-06-2019, 07:30 PM
Carl
Mine is similar, from the vacuum pump pad to my grounding point on the firewall. I used a longish cable in a U-shape (plan view) to allow for engine twist.
Doug
RV-9A "slider"
Tail number N427DK
Donation made for 2020
Old 02-06-2019, 09:15 PM
lr172 lr172 is offline
There is a reason that ground straps exist. The connection from the frame to the engine is a high vibration connection and any cable connecting the two needs to have a large quantity of small gauge copper strands. This is what a grounding strap is. A welding cable is similar and good for this application. However, regular cables are not appropriate for this application and there is a decent possibility of the individual strands breaking and reducing the ampacity of the cable.
A ground strap does not need to be isolated from anything other than exposed positive connections and, as mentioned, anything that can cause fraying of the strap.
Larry
Old 02-07-2019, 07:42 AM
GalinHdz's Avatar
GalinHdz GalinHdz is offline
Also, grounding straps are flat with their wires weaved in many different angles to minimize signals being induced into the ground path. But this "normally" is not an issue in metal airplanes.
Galin
CP-ASEL-AMEL-IR
FCC Radiotelephone (PG) with Radar Endorsement
2020 Donation made
www.PuertoRicoFlyer.com
Old 02-08-2019, 03:40 PM
V111Pilot V111Pilot is offline
Best practice would be to take a piece of rubber tubing and slit it and then zip tie it around the engine mount where the ground strap touches to prevent any degradation of the ground strap...
Old 02-08-2019, 06:41 PM
jimgreen jimgreen is offline
Talking to a mechanic recently, he recommended two ground straps for redundancy. Is anyone else doing that?
Jim Green
RV7 tip up
IO360 Whirlwind 200RV
