02-08-2019, 04:47 PM
Faa $500 ADS-B rebate program.
On Feb 5, 2019, at 3:17 PM, ADSBRebateHelp@faa.gov wrote:
Due to the NavWorx issue, we can help you clear up your reservation issue if you are going to install a new certified ADS-B unit.
The problem is Echo UAT is not a certified equipment and does not qualify for the rebate. Please visit our website for full program rules.
02-08-2019, 06:14 PM
Certified ADS_B only
Yep, I contacted the local FSDO and they told me that only certified TSOd ADS_B are part of $500 rebate. I installed ECHO as it was more for less than a certified version, even with the FAA rebate.
If you check out the Uavionix site they explain which of their products (all OUT, none have IN as ECHO does) are certified.
I've been very happy with the ECHO installed, had to hard wire it to make it 100% reliable, the wifi to transponder mode never worked with my GTX327.
02-12-2019, 12:19 PM
These are what I have found to be the cheapest and easiest to install options currently available:
OPTION 1 : uAvionix ECHO $1350 (Aircraft Spruce)
- Adds a GPS antenna on top of aircraft
- Adds a 4" antenna (included) to the aircraft belly
- includes ADS-B IN via wifi to many apps
- no additional boxes or antennas in the cockpit
- wiring harness (included)
- works with C and also S transponders (like the Trig I have in gyro but this is for the RV-8)
Then we have
OPTION 2 : Garmin GDL-82 $1661 (Aircraft Spruce)- $500 rebate = $1161
- Doesn't add the extra 4" antenna to the aircraft belly
- Must purchase a ADS-B IN so now you have extra antennas inside of the cabin plus more wiring.
- you must build the wiring harness (includes connectors)
- only works with C transponders
- Doesn't have ADS-IN so you must add an ADS-B IN solution :
Garmin GDL-39 $486 (only for Garmin Pilot)
OR
Stratux ADS-B IN $130 (many Apps)
So the Garmin currently ends up costing around $1291 with a Stratux (you build it) to use with most apps making it cheaper price-wise than the Echo !!
RV-8 N52VM: OnSpeed Gen2 AOA-3D, Dynon D-180, Autopilot, Titan 0-360A1A, Hartzell C/S, INS-429 IFR & GPS496, WingX & Stratux for backup & ADS-B IN. Enjoying life while building an airpark with FREE campsite for pilots www.facebook.com/VacaMooAirport/
Exempt by 3 out of the 10 ways but I still donated.
02-12-2019, 12:28 PM
So are you saying the difference is $59.00 but you have two different mfg to deal with, you have to build the Stratx and only Mode C transponders are supported?
Galin
CP-ASEL-AMEL-IR
FCC Radiotelephone (PG) with Radar Endorsement
2020 Donation made
www.PuertoRicoFlyer.com
02-12-2019, 12:36 PM
No chico !
If you go with the Garmin OUT you can use a Garmin also for IN but that costs almost $500 versus the Stratux which costs around $130.
The Echo does give you both OUt and IN so you have everything in one box. I'm considering going with the Echo even if it costs a little more because I don't have to deal with the FAA giving me a check. I just didn't want to have to install another transponder antenna on the RV-8
I just had a great idea, I might just buy everything and go visit you for the install !!!
02-12-2019, 12:45 PM
AWESOME idea. Just let me know when.
Galin
CP-ASEL-AMEL-IR
2020 Donation made
02-12-2019, 05:58 PM
Did you already have a WAAS antenna in the airplane? I don't, so I have to do something that includes WAAS, and my other issue is I need 1090 since I plan to do some flying into Mexico.. So my options are further limited..
RV-8 N188LC
Dues Paid 11/19
02-12-2019, 06:58 PM
A WAAS antenna? Do you mean a WAAS enabled GPS?
Check this out https://www8.garmin.com/aboutGPS/waas.html
02-12-2019, 08:28 PM
Gdl 39
Gdl 39 works with ForeFlight
02-12-2019, 10:00 PM
Approved WAAS GPS?
Still have to add an approved WAAS GPS, right? Now that option is $1,850.
Finn
