Old 02-06-2019, 07:25 PM
Black8's Avatar
Black8 Black8 is offline
Default New Plane for me
Hey gang!!
I bought a nice RV-6 this past weekend. Its a tip up with a Lyc O-360 and FP Prop. My previous RV was an 8 that I built. Air on the ground was not an issue with the 8....this tip up thing cooked me on the ground at 74*F!!! it is too heavy to just ride around while holding it open. I know there's gotta be a better way...HAHAHA!!! please tell me the secret...
Also, today was my first time flying it. Very heavy left wing with full (even) fuel. My 8 had a heavy wing and I remember there was a trick for fixing this...as I recall I put two paint stirrers on the trailing edge of the aileron and then used an edge seamer to "crimp" the trailing edge..I just can't remember which aileron to "adjust"!! Any help would be greatly appreciated.
Joel McMillian VAF#1954
Old 02-06-2019, 07:44 PM
titanhank's Avatar
titanhank titanhank is offline
You will learn to taxi with the canopy latch resting on the roll bar. This creates very good airflow even in the houston, tx heat. The first purchace you will need is the sliding canopy shade, extra wide version. I also taxi out of the hangar, after getting strapped in and while in the shade. I like the tip up better than the sliders i have flown. Squeeze the light aileron very gently. It does not take much to make a huge difference.
Rv-6
0-320/180+hp
10-1 pistons
Lycon port/polish
Dual pmags
EI Commander
Whirlwind 200rv prop
IFR Glass panel
Trutrak Vizion 385 Autopilot
Flightline Interior
Almost rv14 seat mod/cable locking
Electric seat back adjuster
Old 02-06-2019, 07:50 PM
Van's has this about the heavy wing.
Dave
Old 02-06-2019, 08:42 PM
punkin punkin is offline
Default Koger sunshade
Man, I flew my -6 for a couple years before I bought the sunshade, then let the shade sit in the packaging for another six months...boy was that dumb!
Hands down the best addition for comfort in my airplane! I do sometime taxi propped up...if I spin my overhead handle around I can prop the canopy on the rollbar...
?Scott
Scott
1995 RV-4 bought from original builder
1993 RV-6 (sold to good home)
2002 Rans S7 Courier
Double exempt but happy to contribute! Dues paid 2016-2018
www.know-love.org
Old 02-06-2019, 08:54 PM
catmandu's Avatar
catmandu catmandu is offline
It?s a -6, not an -8, Joel: you sure you don?t have a heavy pilot and not a heavy wing? Might want to fly with an equally sized passenger with even fuel to set a proper baseline.
Just a word of caution before you go crazy on that wing, BTDT.
Mike C.
Sierra Nevada
RV-6A bought flying
Old 02-06-2019, 11:09 PM
lr172 lr172 is offline
+1
Never had an issue getting good airflow in my tipper if you prop it open like this.
Also, don't be too quick to squeeze the aileron edges. I suggests squeezing only to achieve flat surfaces leading up to the bend. Van's docs show concave or convex shaping from over or under squeezing the bend. This is easy to observe with a straight edge. Also, do this with the elevators as well. It really tamed the pitch sensitivity on my 6 when I started IFR training. The 6's were not pre-drilled, therefore likelihood of misaligned hinges is far more likely than on an 8. Do some research on this before squeezing too much. A hinge off by 1/32 to 1/16 is enough to cause a heavy wing.
Larry
Old 02-07-2019, 01:12 PM
DeeCee 57's Avatar
DeeCee 57 DeeCee 57 is offline
you probably mean not pre-punched. My later series -6 had pre-drilled tail and wings. As well as counterweighted rudder, full swivel TW, etc, reasons I call it a -6 1/2
Life's short... Enjoy
DC aka Dan
http://www.aerofun.ch
Old 02-07-2019, 06:01 PM
6ato14a 6ato14a is offline
Default Ventilation
I can?t figure out how to post a picture to this but if you will call me or email me I will send you my solution to ventilation in my rv6.
Dave Shenk
303-772-2202
Klmoexpo@gmail.com
Old 02-08-2019, 04:18 AM
BruceW BruceW is offline
Crack open the canopy as mentioned. No sunscreen.
Its a sporty convertible. why cover that up?
Bruce W
RV-7 QB
(500+ hours)
Elk Grove, CA
Old 02-08-2019, 06:12 PM
rodeja rodeja is offline
I glued a thick piece of rubber under the latch so it would not be a metal to metal contact. It made a world of difference for taxiing with the canopy on the latch.
Ron J
RV9 - Bought & Sold
160 HP 0-320
#90899
C-FTJE
Restoring a '47 Luscombe
