Old 01-30-2019, 11:51 AM
UnPossible's Avatar
UnPossible UnPossible is offline
Default What else to do before I attach the tailcone?
Hey - quick question. I am quickly approaching the section in the build where the instructions have you attach the tailcone to the fuselage.
I am planning on installing my static tubing before attaching the tailcone, but wondering what else I should be thinking about before the joining begins
Jason
Jason Tremble
RV-7A (Flying and Sold)
RV-10 in process (@#$$%# Cabin Top & Doors)
Paid for 2020
Old 01-30-2019, 11:58 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Wiring for the tail light/strobe, trim wiring, antenna coax?
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 01-30-2019, 12:59 PM
az_gila's Avatar
az_gila az_gila is offline
Smile
AHRS platform if you are planning on putting it back there.
ELT antenna wiring. I used a larger conduit strung a bit loosely so no strain would be put on the cable if the rear fus. crumples a bit.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 01-30-2019, 01:33 PM
Zuldarin's Avatar
Zuldarin Zuldarin is offline
If you are just attaching the tailcone there isn't much you really need to worry about. But, before you rivet the top skins on you will want to think about the wiring (strobe, rudder trim if applicable), static tubing, AP servo mount(s), and possibly magnetometer. You might also consider cutting/installing the naca vent if you plan on using overhead vents.
Darin
Snoqualmie WA
RV-9A Sold
RV-10 Building - FWF
www.DarinAnderson.com
2020 donation sent!
Old 01-30-2019, 07:53 PM
MJarreau MJarreau is offline
Gil,
Any particular reason you, "used a larger conduit?"
Mike
DUES REMINDER: JAN 2021
Old 01-30-2019, 09:33 PM
az_gila's Avatar
Exclamation
Originally Posted by MJarreau View Post
Gil,
Mike
Yes, so the cable is a loose fit in the conduit. Stuff a little extra cable in it too...
You don't want a nicely tied down tight co-ax strapped to a j-stringer that could get crumpled in an accident.
Gil Alexander
Old 02-05-2019, 12:29 PM
UnPossible's Avatar
Looking ahead, in a few steps the instructions have you install the rudder cables. Any reason not to put them in the tailcone before it is attached to the fuselage?
Jason Tremble
Paid for 2020
