Old 02-02-2019, 07:25 AM
SteveL SteveL is offline
Default practice smugmug
GOOD MORNING!
Just a practice to see if I can get a SmugMug picture to post.
thanks,
SteveL[IMG]IMG_0381-L.jpg[/IMG]
Old 02-02-2019, 07:49 AM
RV10Pilot RV10Pilot is offline
No Joy.
It looks like you only inserted the photo name not the path to the smugmug photo.
Old 02-02-2019, 07:52 AM
scard's Avatar
scard scard is offline
Here, do it like this .
Scott Card
CMW E-Lift
Old 02-02-2019, 07:55 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
That mug does look kinda smug
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 02-02-2019, 02:09 PM
bruceh's Avatar
bruceh bruceh is offline
On your SmugMug page (logged in) with the photo you want to share, click on the Share icon (rectangle with an arrow coming out).
A pop up box will appear. Choose the Size of the image. Medium works well for these forums.
A long URL to the photo in that size will show up at the bottom of the pop up box.
Click on the URL, and it will highlight. Use Ctrl-C to copy (or right click your mouse and select Copy) for Windows, on Mac it is Command-C/Command-V.
In the VAF thread click on the little "image" icon (yellow rectangle with some mountains). A pop up box will appear. Use Ctrl-V to paste (or right click your mouse and select Paste).
Use the "Preview Post" option on your Thread Post to check if it is going to insert the image correctly.
If it looks good, Submit the post, and you are done.
Bruce Hill
2020 VAF donator
Old 02-02-2019, 02:35 PM
AviatorJ AviatorJ is offline
Use https://postimages.org/.
Literally drag a picture over and then it gives you the links for various postings.
Justin
RV-10, N10JW
First Flight 2/14/2019
http://operationrv10.blogspot.com/
