Old 01-30-2019, 09:25 AM
BMC_Dave BMC_Dave is offline
Lol, flaps up = greater ground speed. You can debate the magnitude of the effect but to ridicule the guy for considering that? That's unwarranted...
Folks sputtering about "it's just another single point of failure I'm intentionally designing into my aircraft", I agree.
  #52
Old 01-30-2019, 10:14 AM
Kinda depends on where in that box the single point of failure occurs, and what (as in how many) critical item(s) go with it.
  #53
Old 01-30-2019, 10:21 AM
az_gila's Avatar
az_gila az_gila is offline
Smile
Yes, and the OP was only a flap failure....
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
  #54
Old 01-30-2019, 10:42 AM
And the discussion expanded to cite multiple failure points, and redundant switching, and..
Do you really think that the flap circuit is the only thing that can fail in a box like that?
  #55
Old 01-30-2019, 11:19 AM
Default Wow...
Here we go again...
It always the "That's the way it's always been done" crowd squaring up with the "Let's move into the 21st century crowd".
Quite frankly, it gets old.
If you like circuit breakers, fine. Use them.
If you like electro whiz bang goodies, fine. Use them.
This is, indeed, EXPERIMENTAL aviation. If you are that risk averse, maybe build skills should also be questioned, and only certified aircraft be used with certified parts...because we all know that the trained, certified workers building that certified aircraft with certified parts will certainly do a better job that a shade tree mechanic building an airplane (gasp) in their garage...
Bob
Aerospace Engineer '88
RV-10
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
297 HP Barrett Hung
Wiring...
Dues+ Paid 2019,...Thanks DR+
  #56
Old 01-30-2019, 11:29 AM
scrollF4's Avatar
scrollF4 scrollF4 is offline
Moderator, Asst. Line Boy
Well, this conversation has rounded the tree enough times.
VPX is a great component, but clearly not for everyone.
Everyone have a nice day.
Scroll
Catch her on YouTube's "Because I Fly!" channel
Exemption waived.
Proud and grateful 2020 -=VAF=- Contributor
Closed Thread
