Old 01-19-2019, 09:16 AM
drtgraves drtgraves is offline
Thanks Chris. I like that set up
EyeDoc
14-499 221RV reserved
Paid
Old 01-22-2019, 08:06 PM
dbaflyer dbaflyer is offline
Default Panel finished
Been finished for awhile, but these also have the wind screen and dash complete. Running around 7.5 - 8.0 amps
Denis Sailer - Eastern Iowa
RV9A - N649DS - 132 hours
RV-9
Old 01-24-2019, 08:44 AM
RV74ME RV74ME is offline
Denis, how did you do your white labels? Are those dry transfer labels?
Steve T.
CFII/MEI/ATP 737,DC-10
RV-7, Lyc IO360
AUO
Old 01-24-2019, 07:52 PM
They are water slide, which I purchased from Aircraft Specialty. I ordered some dry transfer, but for some reason the PDF file I sent them would not print at 100% size and I did not have the original file used to make the PDF. I have a feeling the water slides are not going to hold up, but we'll see.
RV-9
Old 05-10-2019, 04:24 PM
jselvatici jselvatici is offline
Default Starting an old project
This is my 1st picture post.
I hope I can get this all re-wired up soon.
Juliano
RV-9A / N349RV
1st Flight on 8/14/2020 - Phase 1 done on 11/24/2020
2019/2020/2021 VAF Contribution Sent
Last edited by jselvatici : 05-12-2019 at 10:49 AM. Reason: Picture didn't show up as expected.
Old 10-31-2019, 01:40 PM
knut knut is offline
That's what I built. Not finished yet. There are still some labels missing, some are temporary. It's a lot of fun to play with.
RV-9A
empennage finished
wings finished
fuselage finished
painted and is being assembled in hangar
located in germany
Old 02-08-2020, 02:20 PM
AirHound AirHound is offline
All very nice work. I?m looking for a 9A. Just looking at pictures was wondering how one gets in behind a solid panel on a slider for upgrade or maintenance?
Old 02-08-2020, 08:32 PM
SVTPete83 SVTPete83 is offline
This isn't a great pic of it, but its the best I had to show. My 9 has 4 access panels built into the cowl section for access. All the fuses, battery, and avionics are under the 4 panels. Its this route, or hang upsidown under the dash to get stuff done. This is a much better option!!
IMG_8253 by Peter Anderson, on Flickr
Old 02-08-2020, 11:25 PM
That?s a beauty Pete! Would a long one piece cut-out work as well or getting into structure there?
Old 02-09-2020, 08:29 AM
MrNomad's Avatar
MrNomad MrNomad is offline
Default Mounting a removable tablet in my 9A panel
I finally replaced my Lowrance with a Samsung tablet for ADSB In and Out using echoUAT, Avare, Garmin GTX 327, CMAX serial to Bluetooth, sniffing, wifi, Dynon 100, 180 & AP74.
I preferred a method which enabled me to remove the tablet after each flight for charging and update. Here's a pic.
https://thumbsnap.com/4zmaazK0
Second, I prepared a WORD narrative during the gradual installation of ADSB. I am not an EE so lots of the jargon was foreign to me. As each step was accomplished, and as my understanding of the components improved, I constantly rewrote the narrative. Anyone with the same equipment who would like a copy of my narrative, PM me and I will send it out.
Barry - Tucson
RV9A Superior O-360
2021 dues paid. Thank u DR!
