Originally Posted by Ralph Inkster
Potential drowning if you get stuck in one of those OSH storms.
Potential oil contamination if you are a hard core aerobatics guy.
Potential heat issues if not vented.
Probable dirt/dust contamination.
Not great serviceable access.
What is the minimum coax cable allowable length?
So many places you could mount it in front cowl area, why stuff it under the seat?
1. If you are worried about drowning at OSH there should be drain holes down there
2. I hope your engine oil doesn't get to that space
3. Enough open space around and flow from the wings. Current is only 0.2 amps in rx. mode
4. The sucker is pretty well sealed
5. How often would it be removed - some of the behind the panel areas aren't very accessible either.
6. Zero inches minimum
7. Again some are hard to get too...
However I think the bigger hold up would be the fact that it needs a cable back to the panel.
I would choose to mount the Dynon transponder there (#6 has the same answer
) since that only has 4 or 5 wires going to it and the Dynon ADSB box which also has only 4 wires going to it.
I my case I mounted my ADSB box under the baggage floor with an access panel. Again a unit that does need to be removed often.
