Old 01-20-2019, 10:35 AM
bryanflood's Avatar
bryanflood bryanflood is offline
Default Main bearings
Does anyone know why there are so many different crankshaft bearings offered for Lycoming engines? The rebuild manual I have lists 3 different parts numbers for my crankshaft bearings.
18D19394
LW-16047 (alternate)
LW-11021 (alternate)
It seems like Lycoming is saying that you can just use whatever you want, or is there a preference to a part number? I noticed superior also says that you can use part number
SL11020
Can anyone help me figure out if there is some reasoning to this?
Bryan
Old 01-20-2019, 09:43 PM
Tommy123 Tommy123 is offline
Superseded numbers or may be oversized part numbers.
Old 01-21-2019, 12:02 AM
az_gila's Avatar
az_gila az_gila is offline
Smile
LW-16047 is superseded by LW-11021
http://nebula.wsimg.com/670c250fc9d9...&alloworigin=1
The 18D19394 is superseded by 18D26096
https://www.lycoming.com/sites/defau...12-Sup%201.pdf
Oversize bearing have a dash number added with the oversize amount.
If your part catalog calls out the earlier number then either that number or the superseded number can be used.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 01-22-2019, 03:56 AM
bryanflood's Avatar
Thanks Gil,
Exactly what i needed!
Bryan
