  #21
Old 01-14-2019, 04:46 PM
Triumph1974 Triumph1974 is offline
Default Update on the Crankshaft leak - I have new seals I don't need now
Hello Everyone - quick update.
The other week I had the chance to take the prop of the RV7A, and do a good visual inspection around the outside of the crankshaft seal....it was bone dry (other than the little bit of grease I used when installing the seal that was still on the shaft).
Sanding in the Helix per the Continental SB certainly solved the issue. Now I have couple of extra new unopened seals, which I don't expect to use anytime soon....so if anyone wants to donate $18 to the Vans Airforce site let me know and I will send you a seal via US mail. I have the Superior Brand one piece seals for an O360.
Paul
Old 01-14-2019, 05:40 PM
Adam Adam is offline
I?ll take it and donate $25.00!
I would like to talk to you about how you fixed your issue..
5 Krueger Hill Road
Pittstown NJ, 08867
Adam Silverstein
Technical Counselor Chapter 643
Flying RV-8 10/30/07
PAID 2021
Pittstown, New Jersey
Old 04-11-2019, 02:22 PM
Default Got the Seal.
Hi Adam,
I take it that you received the seal a while back...if not let me know and i can see if USPS can track it down.... sent you a PM.
