Old 01-05-2019, 03:56 PM
Default Drilling for a K1000-08 Nutplate
Some people use one of the handy jigs for for this.
When I haven't already drilled the screw hole in the aluminum mounting piece yet, but am still using the #40 pilot hole, and I want to drill the holes for the ears, I use a K1000-06 nutplate as a jig. The ear holes are the same and a #40 cleco holds it nicely in place.
No special jig needed.
Dave
RV-3B, building the fuselage
Old 01-05-2019, 05:33 PM
wirejock's Avatar
wirejock wirejock is offline
Default Nutplate jig
Same here Dave. Small twist. I run a screw into a sacrificial nutplate backwards. The screw sticking out helps align the nutplate. Usually I place the nutplate with the screw in the hole, center punch a rivet hole, drill, cleko, center punch, drill. Bit of work but no misses so far.
I have one of each type set up.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 01-05-2019, 06:00 PM
Brantel's Avatar
Brantel Brantel is offline
I built my 7 using those techniques. Works fine as long as you replace the nutplate when the ears get wallowed out.. My wife knows I love tools and bought me some real nutplate jigs for Christmas so I am looking forward to using them.
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 01-05-2019, 06:20 PM
flyvansrv7 flyvansrv7 is offline
Default nut plate jigs
I bought a set from them and they work great.
https://www.yardstore.com/hand-tools/nut-plate-jigs
John Price
Bellevue NE
N717HV RV7 flying 10-28-19
flyvansrv7@gmail.com
Old 01-07-2019, 07:46 AM
Aero_Octaveus Aero_Octaveus is offline
In my own experience. I could always get better and more precise alignment using a sacrificial nutplate rather than using the nutplate jig. I too have a collection of nutplates for this purpose. All colored sharpie blue
Garet Hess - Edmonton, AB
RV-7A - Emp and Wings Done. Working on fuse
http://garetsrv.blogspot.ca/
Old 01-07-2019, 12:03 PM
Raymo's Avatar
Raymo Raymo is offline
A nutplate jig is a great tool and will vastly speed up the installation process. Just be sure you don't drill the screw hole too big; the jig must fit tight in the center hole or it won't be accurate.
Ray
Old 01-07-2019, 12:30 PM
RyanS RyanS is offline
Same here, Garet...........well, almost. Mine are colored Sharpie Red.
Ryan
RV-9A
