01-05-2019, 03:50 PM
Vibration
I have 125 hours on my RV7A with an Aero Sport 0-360 ECI engine. The prop is a Sensenich metal prop purchased through Vans. During take off and level flight I have a vibration. When decending it is not near as noticeable. I had the prop dynamicaly balanced. It seams to be better when lean of peak. Leak down and regular compression testing show good. Ignition is a Light Speed II and one mag. Timing is set correct. Carb was just overhauled. Any ideas or suggestions?
RV7A Completed
N315S
Dues Paid
01-05-2019, 05:42 PM
prop
try repositioning the prop on the crank. Bring #1 cyl to TDC, the prop should be at about 1 o-clock. If the vibration goes away at zero thrust (in a decent) you may have different pitch on the blades. Try checking with a protractor. Also check the track of the blade at the tips.
01-05-2019, 05:49 PM
Check for baffle aluminum too close to the cowling, making the interface stiff. I see this often.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
01-06-2019, 05:42 AM
Bob,
What's a good spacing to shoot for between the aluminum baffle and the inside of the cowl?
01-06-2019, 05:57 AM
Check your exhaust hangars as well.
They can come loose and that will create the vibration you are describing.
(It happened to me... your description matched my aircraft's symptoms)
Chris Hepburn
Ottawa, ON
RV-8 C-GOGO FLYING
Renew 12/20
01-06-2019, 07:15 AM
Originally Posted by alcladrv
Bob,
1" with McFarlane baffle material.
N8155F C150 flying
01-06-2019, 07:17 AM
Its best to hang the exhaust off the engine and not have hangers attached to engine mounts.
N8155F C150 flying
01-06-2019, 07:58 PM
Speed-dependent vibration may be something other than engine/prop - look for a loose wheel fairing that will resonant at certain airspeeds or angles of attack and play nicely at others. I've had it once on my left main as a screw worked its way through the fiberglass and lost grip.
01-06-2019, 08:19 PM
Check for a ?shaky leg?.
Mike W
Venice, FL
N164WM
