01-01-2019, 04:33 PM
WAAS GPS Antenna Install Questions
I see the most common place to install the GPS antenna is top-side just behind the rear window.
-Where did you install yours?
-If installed top-side behind rear window, where did you run the wires?
Kevin Lippert
RV-14A N1402 Flying 03-2020
Phase 1 Complete 07-12-2020
Build Log
Zenith 750 completed 2016 -
Sold
01-01-2019, 05:20 PM
Top side, aft of rear window. I routed cable down the back side of the baggage bulkhead, using nylon clamps (drilled a couple of holes to mount these), then through the mid-fuse bulkhead).
Some photos here:
https://turnerb14a.blogspot.com/2018...-antennas.html
01-02-2019, 03:52 AM
Inside cowling
Consider mounting it at the top of the firewall inside the cowling. Mine is there on the RV4. Much shorter and easier antenna run. I have a very small shelf just wide enough for two antennas. The WAAS GPS antenna for a GNS 480 and one for the Dynon Skyview sit on it right beside each other. Reception is excellent. Testing revealed it was the same as mounting on top of the fuselage. I like that they are not visible as well.
RV4
01-02-2019, 04:13 AM
+1
I have four GPS antenna mounted in this manner, including the WAAS GPS for ADS-B. Never had a problem. The heat under the cowling doesn't seem to bother them and they pick up satellites just as easily as an external mount.
Ron Schreck
IAC National Judge
RV-8, "Miss Izzy", 2250 Hours - Sold
VAF 2021 Donor
01-02-2019, 05:26 AM
+1 again
I only have 3 antenna. Shut down and sitting yields the highest temps. I have data somewhere if you need it.
Bill
RV-7
Lord Kelvin:
01-02-2019, 06:23 AM
-2
If the antenna is for an IFR navigator consider following the manufactures advice to achieve the best results. The old "I did it this way and haven't had any problems" doesn't really work for me personally or profssionally, especially not interested in testing this theory when in the soup on an LPV approach.
If the antenna is for something other than an IFR navigator, then it probably isn't that important and failure won't pose a serious risk to my health so mount it wherever you want.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
01-02-2019, 06:37 AM
Super Moderator
I'm with Walt on this one. IFR navigators should be mounted in compliance with the instructions. I always put the WAAS antenna for these on the outside.
Yes, I know---it slows the airplane down by 25 knots.
Vic
 Vic Syracuse
www.Baselegaviation.com
01-02-2019, 07:11 AM
I did it this way years ago on my -8. It worked great, but that was a VFR-only installation. For the new -14A, which will have a very complete IFR package, I'm not willing to deviate from the manufacturer's published installation guidelines.
I'm happy to experiment on some things, but nav reception in hard IFR isn't one of them.
Ken
RV-8 N118KB (#81125) - Sold
RV-14A N114KB (#140494) - Sold
RV-14A.com
N114KB Build Site
01-02-2019, 07:39 AM
Cable length
If it is a GTN or GNS Garmin unit then a short cable run is not recommended...
GPS antennas listed in Section 3.3 require a cable loss between 1.5 dB and 6.5 dB. If RG-142B or RG-400 is used, 1.5 dB equates to a length of approximately 6.5 feet of cable with a connector on each end. RG-142B or RG-400 cable can be used as long as the length is less than 35 feet. For longer lengths, use low-loss double or triple-shielded, 50Ω coaxial.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
