Old 01-01-2019, 04:40 PM
Aero_Octaveus Aero_Octaveus is offline
Default Almost a RV14 Seat Mod - Installation During Build
Hi all, Just curious if anyone has experience with installation of the Almost a RV14 Seat Mod from Antisplat during construction. I am about to start my F-705 bulkhead assembly and curious if its an easier/cleaner install to start now.
(Also, if someone has incorporated during construction do you have a buildlog or pictures?)
Garet Hess - Edmonton, AB
RV-7A - Emp and Wings Done. Working on fuse
http://garetsrv.blogspot.ca/
Old 01-01-2019, 06:11 PM
woodmanrog's Avatar
woodmanrog woodmanrog is offline
Always easier to install during the build rather than after. This is a very worthwhile mod along with the wheel bearing one that Allen provides.
Old 01-01-2019, 06:24 PM
dwranda dwranda is offline
I did it. I just didn't rivet the upper cross piece and replaced it with the antisplat piece at the right time. I followed the tip up instructions on their site.
[IMG][/IMG]
[IMG][/IMG]
9A in progress
Working on Finish kit!!
Mattituck TMXIO-360 red gold
Dues paid Jan 2020
Old 01-01-2019, 08:08 PM
pilotkms's Avatar
pilotkms pilotkms is offline
Should be super easy during the build. I did mine after, but before first flite. Only took about 4 hours.
Keith
RV 7A RV #9700 May 2017
N325KS the Flying “K”
Built in SoCal KCCB, now in GA @ KPXE
550+ Hours & 7X cross the USA
OSH flyin 2018 & 2019 & Petit Jean 2019
Old 01-01-2019, 10:41 PM
dreed dreed is offline
Those that have it- worth while mod? I'm 6'4" still building but would need to re-do it. Was thinking I'd fly and see if I like it before adding it later. QB slider
Old 01-02-2019, 06:19 AM
Mark33's Avatar
Mark33 Mark33 is offline
There?s really nothing to ?re-do?. The almost 14 kit is super easy to install and inexpensive as well. Just do it...you?ll never regret it. I think that the almost 14 kit and the supertracks canopy extension kit from Flyboy Accessories are two of the best mods you can do to your 7 to improve on the overall comfort and usability of the cockpit area. The 7 cockpit can get a little tight for bigger/taller guys and both of these kits really help to maximize your room.
Mark
Old 01-02-2019, 07:05 AM
pilotkms's Avatar
At 6?4? seriously doubt u will like the standard vs the 14 Mod. I?m 6?3? , sat in Allan?s 9A that he had modded for 1 minute and it was a No-Brainer for me. Best $180 I spent on the build. EZ install.
Keith
Old 01-02-2019, 09:49 AM
[IMG][/IMG]
[IMG][/IMG]
Ok, I see how you did that. Million thanks. Ill try and get it incorporated into my slider build the same way.
Old 01-02-2019, 10:11 AM
Raymo's Avatar
Raymo Raymo is offline
A couple more pics that include the Super Track mod.
Ray
Old 01-02-2019, 02:51 PM
Thanks All! You sold me- I've ordered several things from Allan already, should have trusted my gut and done this one from the start. Supertracks were ordered a few weeks ago as well.
Dan
