Old 01-01-2019, 07:14 AM
toddramsey toddramsey is offline
Default HS spar scratches RV 9
finished match drilling my ribs to the spars on my horizontal stabilizer. When I disassembled and removed the blue plastic, I found these shallow scratches. I believe they came from the brake used in bending the spars in the manufacturing process. The blue plastic was also cut along these scratches. I used mineral spirits to clean the scratches to remove the plastic residue and the photos show what remains. These scratches are very shallow but I can feel them with my fingernail.
https://photos.app.goo.gl/3mi8ho4cX7mFYNrT9
Suggestions?
Old 01-01-2019, 09:30 AM
Snowflake's Avatar
No photo visible...
Rob Prior
Old 01-01-2019, 09:56 AM
Here it is:
Old 01-01-2019, 10:31 AM
rv9builder rv9builder is online now
I received parts with similar marks, and the blue plastic was also cut. Since several parts had the same kind of marks, I assumed this was normal and they were OK to use.
Mark
RV-12iS Fuselage
RV-9A Project: Sold
VAF donation made for 2020
Old 01-01-2019, 11:06 AM
RyanS RyanS is offline
I?d say that looks normal.
Ryan
RV-9A
Old 01-01-2019, 12:31 PM
wirejock's Avatar
wirejock wirejock is offline
Default Scratches
Pretty common. Scuff them smooth with scotchbrite so there's no sharp edges.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 01-01-2019, 02:02 PM
Red Mtn flyer Red Mtn flyer is offline
what wirejock said, to fix.
remember you are RELIEVING potential edges - not polishing it out [don't take the alclad any more than can be helped].
Ben K.
A&P; RLSA - A,G,W/S Falco F-8L
50 yrs of flight and counting
Dues paid 2017 thru 2020
Old 01-01-2019, 03:42 PM
BillL BillL is offline
Bill
RV-7
Lord Kelvin:
Old 01-01-2019, 04:17 PM
apkp777's Avatar
apkp777 apkp777 is offline
Just leave it alone. It's fine. Just alclad. Of course a quick call to Van's will put your mind at ease.
Tony Phillips
N524AP, RV 9 (tail wheel)
Old 01-01-2019, 04:31 PM
Aero_Octaveus Aero_Octaveus is offline
Very common and normal. Once you start handling enough alclad parts and you will see how easy the pure aluminum layer is to scratch. Remember though a scratch that can catch your fingernail isn't good. Like wirejock says buff with scotchbrite until there is no sharp edges. Not sure if you are choosing to prime (not wanting to start primer wars) but buff and prime takes care of a lot of these things.
Garet Hess - Edmonton, AB
RV-7A - Emp and Wings Done. Working on fuse
http://garetsrv.blogspot.ca/
