Go Back   VAF Forums > The Never Ending Debate Section > Primers
Old 01-01-2019, 02:59 PM
guidoism's Avatar
guidoism guidoism is offline
Default Do the no-primer people wash or polish their parts?
After several years of them getting dusty I'm finally getting ready to rivet my wing's ribs into place. I've chosen not to prime. I've wiped the years of dust off of them but should I be doing something else before they go in?
Wash with mild soap and warm water?
Polish with aluminum polisher?
Guido Bartolucci - Louisville, KY - Bowman Field (KLOU)
RV-8 (N883G): Empennage Finished, Working on Wings
Old 01-01-2019, 03:17 PM
bkervaski's Avatar
bkervaski bkervaski is offline
Polishing will remove the alclad corrosion protection .. best to just leave as-is if you aren't going to prime. Maybe clean with soap and water if they are really dirty ...
RV-14A #140376
N196 (Flying)
2019 Bronze Lindy
Old 01-01-2019, 04:09 PM
mikerkba mikerkba is offline
Default Alodine Pen??
If not priming, I would use an alodine pen on all the joining surfaces in the wing. Quick and easy, and good for areas that might see moisture such as the lower wing skins to ribs over the years.
These pens are pricey, but super handy and last a long time (so long as you don't leave them uncapped overnight). No fuss, no muss, no cleanup.
https://www.aircraftspruce.com/catal.../touchprep.php -- good to read the descriptions and comments.
Mike Coster
BUILDER: N92MB RV7A (A/W 3/2009) - Sold
ADOPTED/reworked: N4032Q RV8A (8/2017)
Building: S-21 Outback/Titan, tail and cockpit mated (3/2020)
KELY/Ely, NV
Old 01-01-2019, 07:35 PM
I alodined everything small enough to dip. The faying areas of the skins (that contact the rib flanges) and the rib flanges of ones too big to dip-alodine, I sprayed with a layer of zinc Chromate or self etching primer (not epoxy). Idea is to give a little extra protection to the areas that can trap moisture, as others mentioned. Priming those lines is fast, easy, lighter than anything else short of alodine, and relatively cheap.
Whatever you do, clean well the parts you intend to coat.
Charlie
Old 01-02-2019, 05:38 AM
Larry DeCamp's Avatar
Larry DeCamp Larry DeCamp is offline
Default Boshield
I will start a debate. Any surface prep, including Alclad, is likeley to be compromised during assembly. Boeshield is made to spray and wick wherever the scratch is hiding. So why not save all the prep and take the Cessna approach ( bare Alclad ) with Boeshield where moisture is possibly trapped ?
Larry DeCamp
RV-3B flying w/7:1 0320 / carb / Pmags / Catto 3b / digital steam
RV-4 fastback w/ Superior roller 360/AFP/G3X/CPI/Catto3b
Clinton, IN
Old 01-02-2019, 07:05 AM
Boeshield use was one piece of the advice given me by an aero engineer/multi-builder. Another was that alodine has the same or better corrosion preventative abilities as virtually any paint/coating. (He tested the alodine theory against misc coatings with multiple 2024 test tabs, wedged into a 2x4 & periodically dipped in sea water over many months, at a location in FL about 30mi from the ocean.)
Charlie
Old 01-02-2019, 07:30 AM
Snowflake's Avatar
Polishing does not remove the alclad protective layer. It polishes the alclad protective layer.
Rob Prior
Old 01-02-2019, 08:21 AM
bkervaski's Avatar
No expert here, but seems like you could get into the alclad, it's amazingly thin:
0.016 skin = 0.0008 cladding
0.025 skin = 0.0013 cladding
0.032 skin = 0.0016 cladding
RV-14A #140376
N196 (Flying)
2019 Bronze Lindy
Old 01-02-2019, 10:00 AM
F1Boss's Avatar
F1Boss F1Boss is offline
Boeshield is a good product - respray every 5 years or so? ACF50 is another product that does the same thing. The assembly is sprayed when finished.
Best,
Mark
"Not everyone needs a Rocket. Some folks, however, shouldn't live life without one.
You know who you are."
Budd Davisson, 1997
Old 01-02-2019, 10:39 AM
Default Corrosion X
Probably shouldn't use corrosion inhibitors prior to painting. If spraying inside the wings or fuselage, the joints will weep for some time. CorrosionX is clear and ACF-50 is red. I have had good luck with both products but prefer CorrosionX...
Bob
Aerospace Engineer '88
RV-10
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
297 HP Barrett Hung
Wiring...
Dues+ Paid 2019,...Thanks DR+
