  #21
Old 08-22-2018, 11:07 PM
gasman gasman is offline
130-AA.... This grease will wash off with gasoline. It will work with propane or natural gas.
Your best bet would be to replace the valve for $55....
VAF #897 Warren Moretti
2019 =VAF= Dues PAID
Old 08-23-2018, 08:35 PM
N130WN's Avatar
N130WN N130WN is offline
I?ve used Marvel Mystery Oil.
Larry Bowen
RV-8 Built, sold, missed.
RV-7 Built, sold, missed.
RV-8 Emp in progress ...
RV-8A Purchased, flying.
Old 12-26-2018, 07:24 AM
BillL BillL is offline
Having tried many of the lubes listed herein the easiest was a drop of 100LL every time the cap came off. Grease, EZlube and others washed off after 4-5 flights and back to dropping fuel. So . . .
I did a little research on the solubility of DC-4, DC-2, EZlube, Lubriplate Lithium, and many others in 100LL. All were soluble in gasoline
I finally found a pure PTFE product called Krytox GPL-205. It claimed not to be soluble in gasoline so I cleaned the caps and o-rings then applied the Krytox. Three BB sized balls and worked it around. A tiny smear on the pivot too.
8-9 flights and three fills to tip top and it the operation is still butter smooth. If this works, a small tube will last till TBO.
BTW - a 0.5 OZ tube was over $20, so not the cheap solution but hopefully it is lasting.
I think I need better bait. It's clear many people don't read past the first sentence. With this lube, the cap does not stick and need the press after lifting the tab.
Bill
RV-7
Lord Kelvin:
Old 12-26-2018, 08:58 AM
DHeal DHeal is offline
Originally Posted by Sam Buchanan View Post
The only lube I've used is an occasional swipe of avgas (or auto gas) on the big o-ring when filling the tanks. Having the caps adjusted properly is the other factor.
Just a couple of drops of gas a couple of times a year seems to keep my caps happy. EZ Lube, etc. is just too sticky for this use.
David Heal - Windsor, CA (near Santa Rosa)
EAA #23982 (circa 1965) - EAA Technical Counselor and Flight Advisor; CFI - A&I
RV-12 E-LSA #120496 (SV w/ AP and ADS-B 2020) - N124DH flying since March 2014 - 940+ hours (as of September 2020)!
VAF donation through June 2021.
Old 12-26-2018, 10:25 AM
Michael Burbidge Michael Burbidge is offline
Default Cleaning off EZ-Lube
What do you use to clean this sticky stuff off?
Michael-
Michael Burbidge
Sammamish, WA
RV-14A Empennage
RV-9A Flying?340 hours!
Last Donation: December 2019
Old 12-26-2018, 02:32 PM
AlexPeterson's Avatar
Michael-
Nothing seems to dissolve that stuff. Rubbing it off is the only way I've found. Miserable stuff for this application.
Alex Peterson
RV6A N66AP 1700+ hours
KADC, Wadena, MN
Old 12-26-2018, 05:31 PM
Michael-
I used isopropyl alcohol and naphtha (separately of course) to remove all residual as I has tried several things in the past year. I'm not sure which one is good for EzTurn, but between the two and the rubbing, the o-rings were clean.
Bill
RV-7
Lord Kelvin:
Old 12-27-2018, 07:07 AM
maniago's Avatar
maniago maniago is offline
Originally Posted by mbauer View Post
There is a O-ring specialty shop down the road, 1/4 mile, that deals with oilfield related items, thinking I might go talk to them to see what they have.
Best regards,
Mike Bauer
I get my orings here....http://www.oringsusa.com/
Mani
Busby MustangII (FoldingWing) Pending DAR.
Don't be a hater; I'm a cousin with thin wings!
N251Y (res)
Old 12-27-2018, 07:17 AM
jliltd jliltd is offline
In a word, Toluene
RV-8
(a few more airplanes too)
Old 12-27-2018, 03:54 PM
skylor's Avatar
skylor skylor is online now
Default Best Tip
Originally Posted by Larry DeCamp View Post
You probabably know this but I picked up a helpful tip here on the forum. With the lock lever flipped up, push it down . Then rotate/lift the cap out. I use EZ turn and this procedure makes it very easy to remove caps.
THIS is the best tip in this entire thread. Lift the lever to the vertical unlatched position then while holding the lever in the vertical position, push it straight down "into the gas cap". I tried this for the first time yesterday and it worked like a charm! The cap then comes out of the tank with zero resistance!
Skylor
