12-19-2018, 06:42 PM
I?ve used the Ford tractor industrial gray from Tractor Supply and it?s pretty good paint for rattle can, but the color isn?t very close to the powder coat I got from Vans.
SH
RV6/2001 built/sold 2005
RV4/bought 2016/sold/2017
RV8/2018 built/Sold(sadly)
RV4/bought 2019 Flying
Cincinnati, OH/KHAO
JAN2020
12-20-2018, 10:06 AM
I discovered some surface rusting going on in patches underneath the white (ok, "gray") powder-coat on my gear legs, which surprised me since they've been in careful storage for years and only now got assembled to the airframe. I sanded it off and recoated with a white epoxy rattle-can enamel from True Value hardware. Surprisingly close match. I don't recall the brand but it was nothing exotic.
Bill Boyd
Hop-Along Aerodrome (12VA)
RV-6A - N30YD - Built '98 / sold '20
RV-10 - N130YD reserved - under construction
donating monthly to the VAF - thanks, Doug
12-20-2018, 09:44 PM
Originally Posted by Draker
Thanks. You saved me a call. Any wisdom in fixing minor powdercoat scratches by lightly scuffing and then giving it a spray of white Rustoleum rattlecan paint? For deep gouges that?s probably not going to protect well, but for light scratches?
That's exactly what I did. Rustoleum Gloss White is a pretty close match...works well!
Doug
RV-9A "slider"
Tail number N427DK
Donation made for 2020
12-21-2018, 10:12 AM
Been there done that did the research. This is the exact paint formula Van's uses for powder coating.
https://www.lvppaints.com/
PFW510S9-P3 PFW510S9 Dupont Touch Up Paint - Sky White - 2 Oz Bottle
Comes with small brush applicator. Nice prices too. I think I paid like $9 bucks.
Adam Wright
RV-8 Builder 83611
12-21-2018, 11:06 AM
Good color source
Thanks for the link to a neat site...
https://www.lvppaints.com/Federal-St...n-_p_6657.html
They can mix acrylic lacquer 4 oz aerosol cans of any Federal Standard color for $10.
This should be good for the RV guys considering military paint schemes who want to see color samples over larger areas than that on a couple of square inches of paint chip card. Once you have a Federal Standard color number any paint shop can make it by the gallon for you.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
12-21-2018, 01:35 PM
I thought the Van's powdercoat was RAL 7035, which LV Paints has (under "RAL"), and it's called "Light Grey".
2019 Dues paid!
12-21-2018, 03:27 PM
This is what Vans pubishes...
POWDER COATED PARTS: Older gray parts are Cardinal brand, color GR-230.More recent white parts are Cardinal brand, color T009-WH111 90% gloss. An equivalent Sherwin Williams code is PWS9-40002. A Dupli-Color applicator is also available from some auto parts stores: part code NG CC 362.
https://www.vansaircraft.com/pdf/paint_brands.pdf
EDIT to fit in with the posted quote...
GR230 is the same as RAL 7035
http://www.cardinalpaint.com/assets/...0-T009-TDS.pdf
MORE
The new stuff in now called "white" by Cardinal and does not seem to have a RAL number -
http://www.cardinalpaint.com/assets/...1-T009-TDS.pdf
Looks like Vans may have slipped an extra "1" into the part number though.
Gil Alexander
12-21-2018, 04:07 PM
Definitely not a light gray. At least in my kit from 2017-2018. I got my information from Vans too(seems that have changed it up a few times) the color code I mentioned matches my powder coat parts exactly.
Adam Wright
RV-8 Builder 83611
12-21-2018, 04:55 PM
NOT grey
Mine is definitely not grey...not even a little bit...
Bob
Aerospace Engineer '88
RV-10
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
297 HP Barrett Hung
Wiring...
Dues+ Paid 2019,...Thanks DR+
12-21-2018, 05:04 PM
Gray or not to gray!
Originally Posted by wirejock
Flyboy sells the spray paint. Cardinal Gray RAL 7035 GR230
I wish I knew why it's called gray. I've touched up lots of spots. It's an exact match for Vans white powder coat.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
