USB port problems trying to use GDL8X Install Tool
I installed a GDL82 in my RV7 and tried to follow the instructions to configure my unit using the install tool.
But it appears my computer and the GDL82 can't talk to one another. As per the instructions, I downloaded the tool from Garmin's site. Next, I plugged the USB cable into my laptop and then with the GDL82 not powered up, I connected the cable to the GDL82 adapter cable. I powered up the GDL82 and then opened the tool. Unfortunately, the start up box does not show that the GDL82 is present. My computer and the GDL82 are not communicating with one another.
I also followed the instructions with my Device Manager open so I could see the USB ports. When I plugged the USB cable into the GDL82 adapter (GDL82 not powered up), my computer immediately dings me and opens a new line on the Device Manager that says 'Unkown USB Device (Port Reset Failed)'. I didn't even open the install tool because the USB port is useless, apparently. I searched and followed much advice about repairing the USB drivers, uninstalling, restarting, etc. No luck.
It's pretty apparent this is a computer problem, specifically with the USB port. 5 year old Lenovo, Windows 10.
Anybody seen this problem? Fixes?
Plan to borrow a friends computer tomorrow to see if it will work.
Any help appreciated.
Daryle L. Grounds
214-505-8378
daryle.grounds@yahoo.com
McKinney, TX Based @ T31
RV-7, N33DG, IO-360-A1B, Hartzell C/S, Flying since 12/15/12; Swick TCraft under construction
