Old 12-16-2018, 03:15 PM
gmpaul gmpaul is offline
Default Need carberator help
I have a RV-9, 0-320, 160hp. My Marvel MA4-SPA (105217) is getting well worn. When I originialy built I had to drill out the main jet with a #19 bit if I remember correctly. What model carberator should I buy to replace it with out having to drill out a new main jet. Thanks
Old 12-16-2018, 04:16 PM
SteveL SteveL is offline
Default try these guys
I've used these guys for many years. Fuel injection Pitts S2A, Christen Eagle, Stearman(currently flying), Super Cub with a Marvel MA like yours. They've been around a very long time and are convenient for you.
Aircraft Carburetor & Injection Service of Texas
FAA Repair Station IOFR546Y
P.O. Box 399
Justin, Texas 76247
www.aircraftcarbs.com
tel: 940 648-2277
Old 12-16-2018, 08:25 PM
Tommy123 Tommy123 is offline
You could send it straight to Marvel for a overhaul. Tell them the engine it's on and about the jet size. I was happy with their service.
Old 12-16-2018, 08:57 PM
Sam Buchanan's Avatar
been here awhile
I replaced the carb on my 160 hp O-320 E2D with an overhauled 10-5135 purchased from Aircraft Spruce. It has worked perfectly for 300+ hrs. This was the carb recommended in the Kelly Aerospace application chart:
https://www.aircraftspruce.com/catalog/pdf/Facet%20Marvel%20Schebler%20Carburetor%20Cross%20R eference%20and%20Engine%20Application.pdf
Sam Buchanan
RV-6
Fokker D.VII replica
Old 12-16-2018, 09:42 PM
Ed_Wischmeyer's Avatar
Ed_Wischmeyer Ed_Wischmeyer is offline
When my then new to me RV-9A had high EGT, I called the factory and told them what was going on. They recommended a carb that I bought from Aircraft Spruce, and I think it was an exchange. That carb was richer than the previous carb, and it almost did what I wanted. The factory suggested I send that carb back to them for adjustment. I did, they did, and all was well.
I also asked about drilling out the jet, and I found out that is a really, really bad idea.
My contact was:
Mark Keeney Jr.
Marvel-Schebler A/C Carburetors
125 Piedmont Ave.
Gibsonville NC 27249
Mark@msacarbs.com
(336)446-0002 Office
(336)446-0007 Fax
1 855-672-2272 TF
RV-9A at KSAV (Savannah, GA; dual G3X Touch with autopilot, GTN650, GTX330ES, GDL52 ADSB-In)
Previously RV-4, RV-8, RV-8A, AirCam, Cessna 175
ATP CFII PhD, so I have no excuses when I screw up
2020 dues slightly overpaid
Retired - "They used to pay me to be good, now I'm good for nothing."
