  #11
Old 12-14-2018, 12:13 PM
rolivi's Avatar
rolivi rolivi is offline
Originally Posted by mciaglia View Post
As a hand surgeon... I wish VAN's would include my card in every kit. FREE HAND SURGICAL CARE to all VAN's RV'ers!!!!!
Wow! does your offer include Dupuytren?s Contracture? I'm in Houston every other week!
Rob
RV-6A (Purchased)
2020 Dues Paid, of course
N8RV's Avatar
N8RV N8RV is offline
I can honestly say that, over a 13-year building process, not once did I drill into a finger. Perhaps that's because, being a dentist, I'm really good with the drill ?
ON THE OTHER HAND ? my shop floor had a drop of Danny King's blood due to him snagging his finger on a sharp hole drilled into the firewall that I neglected to debur. Oops. Naturally, I took a Sharpie and ID'd the drop and sealed it with lacquer to memorialize his dedication to my project.
Don McNamara
Peoria, AZ
Builder: RV-8 "Smokey"
Old 12-14-2018, 01:26 PM
mike newall's Avatar
mike newall mike newall is offline
Superglue.......
Cyanoacrylate - It's the future.
Well, TBH it's the past. Developed as a field surgeon technique wayyyy back.
"I add a little excitement, a little spice to your lives, and all you do is complain!" - Q
Donated in 2020
Old 12-14-2018, 01:34 PM
mciaglia mciaglia is offline
Discounted for non-traumatic!!! I do a lot of dupuytren surgery. Call anytime,
I have patients from all over Texas and the US
Dr. Mark Ciaglia
The Woodlands, TX
Donating Monthly since 10/17
N189PT- Christen Eagle II
N627DG (reserved)- RV10 in the making
www.marksfamilyrv10.wordpress.com
Old 12-14-2018, 01:39 PM
Super Moderator
On my first airplane, the RV-4, I drilled right through an aluminum sheet into my finger. That hurt. I went inside and put a bandaid on it. Went back to the garage and proceeded to drill another hole through the same finger. I quit for the night!
It amazed me how long a hole took to heal vs. a cut.
Vic
Vic Syracuse
www.Baselegaviation.com
Old 12-14-2018, 08:37 PM
PilotjohnS PilotjohnS is offline
Default My great dad
When I was 16 working with balsa airplanes, I drilled thru my finger and the drill broke off. I ran all panicky to my dad and asked what to do. He barely looked up and said, pull it out and put some peroxide on it?. Thanks dad.
John S
Dues paid 2020, worth every penny
RV9A- Status:
Tail 98% done
Wings 98% done
Fuselage Kit 98% done
Electrical 5% in work
Firewall Forward 5% in work
Old 12-14-2018, 11:02 PM
tim2542 tim2542 is offline
I can beat all of you. I ran a sheet rock screw into my finger...into bone....with a non reversible air gun....pinned me about 1? out of reach of a tool box with a screwdriver in it....at work...during lunch time. I was stuck for 45 minutes until the other guys came back.
Yes it came up at the retirement dinner.
Tim Andres
Old 12-14-2018, 11:55 PM
rv8ch's Avatar
rv8ch rv8ch is offline
Default photo
Originally Posted by steve murray View Post
Usually I just drill "holes" in my finger ranging in size from .032 safety wire to #30 drill. About a week ago I drilled a "circle" in my finger. Got this from a spinning piece of aluminum tubing as I was drilling out the ID to make a bushing. Sharp tubing cuts quickly through leather gloves and then fingers.
Be safe with those power tools.
Code:
https://lh3.googleusercontent.com/Sq4H71GAmQBWOJ2k4-Wni8krm7Vd3Zvqpmlq-VNZY3Z8Ld6yrPuOdAX_9Uxz1F0Kp0k7kN2F2W1tHsz9-rYjBvhdTGGlEsPxWzwLVnsE9HNEz3vyNOxSkHvHBKxuNoyxXKhe5R1Q9SYSUdihoIsRrkR_Qe_0BLibf4cXPaCOF2oBWmmTIsjyKyTAOGKB9hxmb-KfFvgtoTRYAZ-fNuV8Ov1yc3b_WdhFlT6D1Fb94v8NI1YZCNVq2KCTNW2q8gNPmTON0E3ccv4Jb_x0JqzpNwu14Xb82EJeuSzyEUemQdnWsZO5tMj5EkCE1SUQl4Il26VpIOCMEAXJolqexAY6otrRQPHX4MwjrbJlFel10J3koNyDLDJOGFMbuwPfjAXMqV9CBypZfNjJ1k5Zq1IHpbpfH8ZOtM8NnnEXo2tGeZewiEBPH48pl0hgRh3hpsfNWehrx_49P941SYcfls8rv7T5oxZ7Da7ie2uDLRhJ6W19lZJtFtouYmGLTrY6bLIQ-x9R0U172stFDxX1y-gMPSIRp8xufsW9J8OPCOJxkjEze3mlkdeNeIIqpIe2qcePUTK4tCQTkwp8TWw_YtAS276uvrgLeUao7annGgYhuAecGPXMOGJX6hr-JW_XvEBBvqSG3QgYWXBz0B3VvdIUt32J=w888-h1184-no
Not that I really want to, but just to let you know that I can't see that image. I did see one "hole in a finger photo" many years ago, and that really taught me to not do that.
Mickey Coggins
http://rv8.ch
"Hello, world!"
Old 12-15-2018, 05:28 PM
longranger's Avatar
I did it backwards from a lot of folks... through the nail side. How, you ask? I was drilling out a rivet and trying to walk the hole to the center when the 1/16? bit broke and at was left if the bit landed square in the center of the finger I had been using to guide the bit. It took several months for the evidence to grow out...
http://www.mykitlog.com/users/displa...=145258&row=29
RV-7 TU 904KM (reserved)
Construction Log
Old 12-15-2018, 08:41 PM
mbauer mbauer is offline
Default Sheet Metal Protection
Work in a welding supply store. We sell lots of cut resistant Gloves to oilfield workers.
Some of the better ones that are reasonably priced should work for sheet metal work. Good dexterity + grip technology in the new styles.
Good style for price point and protection ( I use these at work and very happy with them) are the Honeywell P/N 26-913YB same glove in black only 26-913BB. Less than $10 a pair, far less than stitches.
The new ANSI rating system uses a standard test machine and makes it easy to under the level of cut protection. A1 thru A9. The above gloves are rated A6.
The European rating system rates the gloves as follows: Abrasion, Cut Resistance, Tear resistance, Puncture resistance. ANSI only does the cut level.
Leather is not a good choice for cut protection; taken from the Turtleskin website "Leather does not have good cut resistance, in fact the oil in leather lubricates the blade when cut. Leather also does not have good puncture resistance for the same reasons."
Not many gloves are going to protect against drilling the finger however. Just the burrs and sharp edges of sheet metal.
Best regards,
Mike Bauer
Mike Bauer
N999SN 1998 Syd Nelson RV-6 (purchased 2017)
UTC -09:00 Alaska
