I used a large mushroom bar made for backriveting on the outside with a long offset backrivet set on the inside. On the mushroom bar, the edges are slightly rounded. With a dead flat bar, you need to be careful to not tilt it a little, or it will dent the skin. Personally, I ended up switching to a conventional swivel set/gun on the outside, and a tungsten bar on the inside. Comparing the two techniques, another builder and I felt the rivets were more flush with using the gun on the outside. Also, we never had to drill any out, whereas backriveting I did. Lastly, at 45 psi on a 3X gun and the tungsten bar, it took a 1 second zap to set the rivet, where backriveting took 3 seconds. On an RV-9 wing, it made difference!
