Old 12-09-2018, 11:26 AM
dave4754's Avatar
dave4754 dave4754 is offline
Default Can a B&C alternator run on a Plane Power regulator
Hello Gents
I have bit the bullet after years of reading the pros and cons for Plane Power and B&C alternators and have received the more expensive B&C.
Great looking unit, small and ideal in my RV 7.
However at one point I had decided to go with Plane Power but the recent poll and all the problems of late with their alts. I went with B&C BUT I now have a Plane Power regulator installed.
Question then is can my External B&C alternator use the External Plane and Power regulator or am I out another couple hundred bucks?
Any response greatly appreciated and yes I have scoured the search engine on this already thanks
Dave
Dave Cobb
[color="Red"]=VAF=2019 Donation - and a bit extra for great work![/COLOR="blue"]
Empennage RV 7 - Tipper
Wings complete
Dynon installed and running
Fuse closer to completion, Canopy complete
AME reviewed and repaired O-320-Lyc installed
Old 12-09-2018, 12:36 PM
dlloyd3's Avatar
dlloyd3 dlloyd3 is offline
Yes, just follow the wiring instructions for the regulator.
Dave
M20C
Old 12-10-2018, 08:43 AM
dave4754's Avatar
Default Thanks
Thanks Dave
Dave Cobb
Wings complete
Old 12-11-2018, 03:15 PM
dave4754's Avatar
Default Astounded by the replies!
Not!
One reply?
For the records, I phoned and talked to B&C and they said that the Plane Power would be ok to use.
However, the unit is conventional in handling the power as opposed to their's which is lineal. The latter is supposed to be less noise on Avionics.
Great looking unit, installed it yesterday with good results although one has to be intuitive with regard to what position to place the bracket on .
Dave
Dave Cobb
Wings complete
Old 12-11-2018, 03:21 PM
Raymo's Avatar
Raymo Raymo is offline
I (and likely many others) agreed with the one reply and did not feel a need to do the +1. A regulator is a regulator (or maybe not?)
Ray
Old 12-11-2018, 04:43 PM
Walt's Avatar
Walt Walt is offline
Originally Posted by dave4754 View Post
Not!
One reply?
Dave
Sounds like you think VAF braintrust owes you a reply?
Actually I'm surprised you got any replies, likely because no one has done it and like me, would be hesitant to recommend something that we haven't done ourselves.
It always surprises me how many folks turn to VAF for technical advice that would be best/easily obtained from the manufacturer.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 12-12-2018, 01:58 PM
Not!
One reply?
I would have replied earlier but thought you wouldn't appreciate my comments about the B&C regulator being linear. I also thought you wouldn't appreciate me mentioning that I wouldn't care to mix a very solid alternator with a not-so-solid regulator from PlanePower. There... more than one reply now!
Old 12-12-2018, 10:57 PM
dave4754's Avatar
Default Humbled
by those that responded.
Thank you one and all.
I have the situation resolved.
Dave
Dave Cobb
Wings complete
Old 12-22-2018, 09:07 AM
Boyd Birchler Boyd Birchler is offline
As long as it is a conventional alternator (not a permanent magnet dynamo) they all regulate by sensing the out put voltage, then modulating the voltage going to the field to keep the output voltage stable with varying electrical loads...a alternator regulator is a regulator (as long as it is designed for the same output voltage).
