Old 11-28-2018, 01:36 PM
StressedOut StressedOut is offline
Default Elevator Balance
How critical is the balance of a control surface? If I have a slight bit of extra mass in the elevator (let's say about 2 ounces more along the rear spar), how critical is that for flutter? Is it sufficient to get a neutral balance by trimming the counterbalance weights in the horn as required to achieve this condition, or are there other considerations?
Art Jackson
RV-14A Kit#140433, N393AJ Reserved
Completed: Vertical Stab/Horizontal Stab
Scrapped: Rudder
Working on: Empennage (Elevator)
Construction log - mykitlog.com/ajackson
Dues paid on 10 October 2018
Member of EAA Chapter 92 (KCNO)
Pet peeve: "Lose" (rhymes with "booze") is the opposite of "find". "Loose" (rhymes with "juice") means "not tight".
Old 11-28-2018, 01:42 PM
Bavafa Bavafa is offline
From what I have been told by VANs, you want to get your elevator as balanced as you can and this ought to be done individually not connected together. I balanced mine in such way that it would not move in all its travel range and it was done individually. Now, if you are planning on painting prior to flying, you may want to leave it as heavy on the trailing side as you can. Paint will add weight so much that you will need to add weight to the horn.
Hope this helps.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
Old 11-28-2018, 11:09 PM
Tommy123 Tommy123 is offline
Hope this helps.
I would re balance after painting instead of guesstimating. That's if you are planning on flying before painting.
