  #21
Old 11-09-2018, 06:19 AM
jor.ezq jor.ezq is offline
Default heavy wing issue
Hi all, need advice to solve this.
I started to fly my -10 that was built by other builder and I finished.
The issue is that she flies with the right wing down tendency and in order to maintain the track I need to step the right pedal a little.
When I run with the autopilot , the right wing stays down about 3 degrees and she flies uncoordinated ( the ball is out of the center to the right side)
What should I do first ?
Your imputs will be highly appreciated.
Jorge Ezquerra
Buenos Aires
Old 11-10-2018, 12:27 PM
bob888 bob888 is offline
Why not leave the wedge and call it good?
Old 11-10-2018, 02:13 PM
Carl Froehlich's Avatar
Jorge Ezquerra
Buenos Aires
The short answer is to start the rigging process from the beginning. From what you have said, it is impossible to tell you what it wrong - so just start over.
For a ball way out like yours, I would also jack up both wings so the gear is off the ground and see how the wheel pants are mounted. Bad wheel pant and/or gear leg fairing rigging can put the ball way out.
Do all this before you add stuff like a rudder trim tab.
Look at my previous posts on rigging as a placer to start.
Carl
Old 11-22-2018, 02:40 PM
Tim Lewis Tim Lewis is offline
If the nose wheel sticks in a left or right pivot that will cause a non-centered ball condition. I?d check to make sure nose wheel breakout torque isn?t over spec.
Cleveland makes an easy to install rudder trim wedge, $18.50.
Tim Lewis
CFI, A&P
RV-10 N31TD - 1250 hrs
RV-6A N47TD - 1100 hrs (sold)
