I have talked to one builder who did have his rubbing, and eventually it did wear through or nearly through the pushrod. That said, after talking to him, I got worried about mine and inspected them closely and could not find any rubbing. So I have to think that depending on the bending of your spring mounts on the pushrod, or the actuator arm end, you may or may not see this issue. The tape may prevent some wearing, but I would suggest that you look closely at it and try to actually determine what isn't lining up right so that you can bend things as necessary to get them not to rub. I think that some combination of the rotation position of the pushrod, and the bend in the arm, should yield a system that doesn't rub.
