11-13-2018, 05:43 PM
B&C alternator brushes
Does B&C sell brushes for their alternators? (mine is the standby alt)
Or must one send it in, for this simple repair?
I see none on their alternator parts link.
http://www.bandc.aero/alternatorreplacementparts.aspx
11-14-2018, 06:18 PM
Originally Posted by RV8JD
Sounds like a great question to pose to B&C directly.
Indeed (did you see the time stamp of my op? They were closed. Sometimes we refer to our knowledgable, 24/7 community for answers when vendors are closed)
However I did get a helpful pm saying B&C will not sell parts. If your ($2) brushes are worn, you must send it in for overhaul.
11-15-2018, 06:07 AM
Pull out the brushes, go by your local automotive alternator/starter repair and tell 'em you need some brushes for your airboat. They will fix you right up for just a few dollars.
Dave
M20C
11-15-2018, 06:22 AM
What makes you think it needs new brushes? B&C recommends OH at TBO, I sent my 40A alt in at 1500hrs for a check-up, turns out it didn't really need anything and was working fine when I removed it for some other work. I had them do the full treatment anyway as long as it was there.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
11-15-2018, 08:01 AM
Senior Curmudgeon
By the time the brushes are worn out, the commutator may also need to be cleaned/trued up, and the bearings should be inspected carefully or just replaced as preventative maint.
This is assuming the brushed did not have some kind of early failure.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
11-22-2018, 04:56 PM
upon pulling the brushes, can see the shaft is wobbling.
Sent to auto alt/starter shop.
01-17-2019, 07:48 PM
final follow up
new brushes
new slip ring
new bearings
new aft housing
Auto shop matched it to a Denso model.
$220
working like a charm now.
01-18-2019, 08:57 AM
Originally Posted by LancairGuy
final follow up
new brushes
new slip ring
new bearings
new aft housing
$220
Could you share the Denso model number?
01-18-2019, 03:02 PM
What was the charge by B&C for the full treatment?
George
01-18-2019, 10:52 PM
The shop said:
1002114100 or4103 or4104
I can give you his contact info if desired. El Paso TX
PM me for that
