11-13-2018, 06:27 AM
NACA vent in the cheek cowl ?
Sam Jones no longer offers cheek cowl so I will fabricate from scratch. I read here about An RV4 that had NACA inlets on the bottom of the cheeks that workwell. Does anyone know how to contact that person ?
Larry DeCamp
RV-3B flying w/7:1 0320 / carb / Pmags / Catto 3b / digital steam
RV-4 fastback w/ Superior roller 360/AFP/G3X/CPI/Catto3b
Clinton, IN
11-13-2018, 06:49 AM
I have a neighbor that has done that and I copied his. Used one of Van?s vents as a start and made my own NACA vent and molded it to fit inside the teardrops. Passed Van?s 2? vent hose through the fuselage side and then to an eyeball vent on the instrument panel. Neighbor says it is extremely effective.
I can email a couple of pictures if you want.
Ross Scroggs
RV-4. #3911
Locust Grove, GA.
11-13-2018, 07:46 AM
A bit Cheeky...
Larry,
My buddies "Hollywood and Cheez" of Hotel Whiskey Aviation both installed their NACA ducts on the underside of the cheek on their Fours, nearly invisible unless you know where to look. VERY effective. Difficult to install post construction I might add...
I will PM you their contact info...
V/R
Smokey
11-13-2018, 08:39 AM
RV-10 vents
I installed two RV-10 vents up by the rudder pedals. It works great. In the hot summer, with the air blowing up your legs, it’s great. In the winter, they don’t leak air at all. Cheap and easy and effective.
Mike
RV-4 #2750
N654ML
IO-360
WW150C Prop
1018 lbs
Flying
11-13-2018, 08:47 AM
I was going to do the same thing. I saw it on a -4 at a local fly in and thought it looked really good. But after cutting the hole and checking where the hose would enter through the side skin, the throttle/mixture cables were right in the way. So there was no way it would work on the left side with my setup. I glassed the hole up and abandoned the idea.
[IMG]  [/IMG]
[IMG]  [/IMG]
[IMG]  [/IMG]
Arlie Conner (A&P)
RV-4 (N124TT) Sold
RV-8 (N269CP) Sold
RV-4 (N684ML) completed 3-17-19
KOCH Nacogdoches
11-13-2018, 09:30 AM
Venting a bit...
Originally Posted by acam37
I was going to do the same thing. I glassed the hole up and abandoned the idea.
[IMG]  [/IMG]
Arlie/Mike,
There are many ways to skin the proverbial cool air cat, ( I had 4 different vent combos on my Four) however, Hollywood's NACA vent on the underside of the cowl cheek is slick.
I will try to get pics...
V/R
Smokey
11-13-2018, 09:55 AM
My build is almost finished and I still haven't decided where to put the fresh air duct. Here was my inspiration
[IMG]  [/IMG]
Arlie Conner (A&P)
RV-4 (N124TT) Sold
RV-8 (N269CP) Sold
KOCH Nacogdoches
Reason: Add photo
11-13-2018, 05:12 PM
Thanks to all !
VAF is the greatest. This is what I was looking for. Please forward the email,PM etc to help me do this.
Larry DeCamp
Clinton, IN
11-14-2018, 07:15 PM
Ross's Vent Photos
11-15-2018, 09:16 AM
Just a quick note to back up this great thread. I just Finished my -4 build with the NACA’s in the cowl cheeks. Thy work amazing and are so much air I split each side to two different eye ball vents, so I have 4 vents up front. Yes it’s a lot of work to glass them in and get everything to work including throttle and mixture cable clearance but when it’s said and done it’s super clean and most inmportantly a blast of air.
Shawn Jordan
KDVT
RV4. N11XZ
2018 dues paid.
