Old 10-29-2018, 11:11 PM
Default Water Pump Failure?
Yesterday I took off with an OAT of 77F and experienced both CHTs and an Oil Temp Hi alarms on climb so I returned to the field and did some ground run ups with a repeat of Hi Temp alarms. I?m wondering if my alter pump died, any ideas on how to verify if that is the case?
Old 10-30-2018, 12:37 AM
Piper J3's Avatar
Piper J3 Piper J3 is offline
I did a quick search and it seems the 912 water pump is pretty infallible. One guy described a problem like you are having and problem was traced to a vacuum leak causing lean operation and high EGT?s. I also read about a suggestion to remove the radiator-style pressure cap on the expansion tank, run the engine, and look for evidence of coolant flow in the neck of the open tank to verify water pump working.
Good luck?
Jim Stricker - EAA #499867
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 750
Old 10-30-2018, 07:32 AM
Dave12 Dave12 is offline
I had a similar situation with my 1st 12 back in 2011. It was the D180. Run the engine until you see the temp going wild then check the coolant temperature with another source. I too suspected the pump, the sensors, etc. I sent the the display to Dynon 3 times before it was fixed. They were completely unable to re-create the scenario on the bench. Each time the unit passed the bench test. It wasn?t until I borrowed a unit from another 12 and verified it that Dynon sent me a new display. Not ragging on Dynon here, they were loosing a little hair over it too.
Wag Aero Sport Trainer built,sold and wrecked
N588DF RV12 #336 built, sold and alive and well in New York
N73DF RV12 #244 built, sold and alive and well in Florida
N91 RV RV9 I wish I could say I built this one! Mark Santoleri hit the ball out of the park on this gem.
Old 10-30-2018, 06:37 PM
hook hook is offline
Have you replenished coolant and done a leak-check engine run with the cowl off?
I had an overheat issue, and this procedure quickly found a leak on one of the 1" coolant hoses where the hose clamp ate into the hose.
RV-12 Owner & Flight School Operator
CFI/CFII/MEI
LSRM-A
chris@flygcaa.com
Old 10-30-2018, 09:08 PM
Thanks for the suggestions. I will start troubleshooting tomorrow and post results.
Old 10-31-2018, 11:06 PM
Today I pulled my D180 and sprayed the connector pins and sockets with cleaner. That seems to have done the trick. A trip around the patch showed normal CHTs and Oil Temp, so I am cautiously calling this a dodged bullet. I?ll take it up for a longer flight this weekend and confirm it. Thanks for the suggestions!
Old 11-01-2018, 11:19 AM
DaleB's Avatar
DaleB DaleB is offline
I have had some considerable experience maintaining computer equipment over the years -- everything from large, water-cooled IBM mainframes all the way down to PCs and smaller. It's not at all unusual to find problems that go away simply by re-seating connectors.
Based on that experience, part of my condition inspection includes unplugging, blowing out and re-installing every connector I can get to. The gold plated connector pins are typically not much of a problem, but any of them can accumulate oils, dust, etc. Just the wiping action of re-seating the contacts is usually enough to head off problems. Yes, connectors have a limited life span ; they're only good for so many cycles. If I have this thing long enough to wear any of the connectors out, I'll be a very, very old man indeed.
Dale
Omaha, NE
Previous RV-7 project (sold)
Old 11-01-2018, 12:06 PM
Piper J3's Avatar
To corroborate what Dale says above, see recent RV-12 comm radio problem that was resolved by re-seating the radio in its tray.
http://www.vansairforce.com/communit...d.php?t=164899
Old 11-04-2018, 11:05 AM
Looks like the problem was that simple to fix. I flew it three hours yesterday with normal temperature indications.
Old 11-12-2018, 08:50 PM
Well, my gremlin is back after three trouble free hours. Here are the symptoms:
1. CHT, EGT and OIL temps spike high. Left EGT spikes more than others at about every 2-3 seconds.
2. Spikes are not synchronized.
3. At low temperature the indications are reasonable. That is before start, they reflect ambient temperature and respond normally (I sprayed Freon on them and observed a drop in temperature below ambient.
4. Disconnecting the CHT leads drives the indication low leading me to believe this is not a connector issue.
5. Oil pressure, fuel pressure, tachometer and fuel flow are stable and unaffected.
6. Today during ground runs I got an voice alert ?EMF Low? alert, but main bus voltage was stable at 13,8 VDC.
Any ideas from the brain trust? Tomorrow I?m going to talk to Dynon.I suspect the D180 May have an issue.
