Old 11-04-2018, 02:01 PM
Desert Rat Desert Rat is offline
Default Corrosion-proofing question
Hey All,
I'm going in a couple of weeks to look at a used/partially completed RV7 kit. The guy has completed the empennage and wings, but didn't prime anything but the spars.
If I were building this from scratch , I'd likely prime the ribs and faying surfaces of the skins, but I know that lots of people don't bother.
Obviously, there is the financial aspect since it's less than a new kit, and if the build quality is otherwise reasonably good it would be nice to pick up something with a few hundred hours of labor already knocked out.
Everything coming out of Wichita these days is primed like crazy, but I'm currently flying a 64 year old c170 that seems to have not fallen out of the sky, despite not having a lick of primer inside it.
I don't want to add to the primer wars, I'm just looking for real world experience. Has anybody skipped priming the internals and later regretted it? I'm currently in Wichita, but there's always the potential for a relocation to a salt air climate in the future.
Terry
Terry Shortt
AGI, CFI, CFII, MEI, A&P, Janitor
RV7 Empennage & Wing done
Fuselage in process
#72651
https://eaabuilderslog.org/?blprojec...t=all&listcat=
Old 11-04-2018, 02:52 PM
Terry my RV recently shed some skins. Flying unprimed unpainted since 2011 tied down under the elements by North East coast. I was very pleased to see the internals sparkling clean. External that's the whole another story. Rusting like crazy.
Old 11-04-2018, 02:59 PM
Default Data point
I am currently about 92% done with the build. I read all the primer war threads prior to my build. I chose to prime my -10 with P60G2 that Van's uses.
That being said, if I build again I likely will NOT prime. The time involved in priming, FOR ME, did not justify the effort. It increases the build time substantially, and it comes down to if you want an airplane that will last for 75 years versus 100 years. Most of these RVs are treated better than fine automobiles, being washed, waxed, and always hangared...
I also fly a 1957 C-172 that was never primed and never babied.
Bob
Aerospace Engineer '88
RV-10
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
297 HP Barrett Hung
Wiring...
Dues+ Paid 2019,...Thanks DR+
Old 11-04-2018, 06:09 PM
Charles in SC Charles in SC is offline
My quick build kit was not primed as built by Vans builder. I do not know if the other quick builds are or not. Mine is a 2006 kit. I primed what I could but obviously could not get to everything.
RV 7
Old 11-04-2018, 06:22 PM
Mudfly Mudfly is offline
What Bob said ^. Priming adds CONSIDERABLE time to the build and, for me, reduces the overall enjoyment of the project. My next build, the diesel or turbine powered RV-15 will not be primed.
Shawn Edwards
RV-14A (140174)
www.myrv14build.blogspot.com
2020 VAF Donation
Old 11-04-2018, 07:00 PM
Larry DeCamp's Avatar
Larry DeCamp Larry DeCamp is offline
Default Just an opinion
Priming takes a lot of time, adds weight and gets scratched through where you can?t see it during the build.IF you move to the sea coast or see something you don?t like, spray it with Boesheild after painting. That is what the stuff is made for.
Larry DeCamp
RV-3B flying w/7:1 0320 / carb / Pmags / Catto 3b / digital steam
RV-4 fastback w/ Superior roller 360/AFP/G3X/CPI/Catto3b
Clinton, IN
Old 11-04-2018, 07:54 PM
JonJay's Avatar
JonJay JonJay is offline
If it came from Vans as a QB fuselage and or wing, they are all primed with P60G, which is a slightly different product than in the States as it has a grayish sheen, not greenish.
It is very subtle so you may not be aware if you haven't seen it before.
P60G is the easiest and simplest way I have found to provide a basic first level above Alclad corrosion coating. It is still time consuming, but nothing like other hard coatings.
It adds almost no weight.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 11-04-2018, 08:24 PM
Av8torTom's Avatar
Talking $$$
Hey Vlad - you should cut that old skin up into small pieces and sell them. Everyone would like a piece of Vlad?s famous RV9A. Along with a certificate of authenticity of course!
N677AT reserved
Superior XP O-320, 160HP
Old 11-05-2018, 01:37 PM
Thanks for the feedback guys. This will be the 3rd used kit I've looked at since starting the search, and if this one doesn't pan out I'll likely just have to admit that I'm too picky and buy new kits so that I can rework my own mistakes, rather than someone else
Terry Shortt
Fuselage in process
#72651
