11-04-2018, 03:27 PM
RV7 CS spinner bulkhead crack...carbon fiber?
Well this is the second time my spinner bulkhead cracked. First I suspect was due to prop not being balanced...hartzell CS. Had prop balanced, compression test done, no pulses. One thing I did notice did not have enough clearance on the spinner cutout for the movement of the blades. Fixed that midway through the second bulkhead. Pulled the prop for belt change and saw cracks around two of the 4 mounting bolts for the prop. I'm at a loss here, did some quick internet research and seems like a carbon fiber spinner backplate will fix my problem. Any thoughts as I'm tired of pulling the prop? Spinner does track true.
Carl
Carl Bridges
RV7 N278RV
NOW FLYING
11-04-2018, 03:32 PM
I see on Chris Z website N91cz had the same issue with his lancer and he fabricated a carbon fiber backplate which fixed the problem. I think he used an autoclave along with vacuum bagging but not sure. Anyone in that biz that can help?
Carl
Carl Bridges
RV7 N278RV
NOW FLYING
11-04-2018, 04:54 PM
Carl
Chris Z is active on the Lancair forum and has a thread in WTS on that forum. I believe it is only visible to forum members so I will post a redacted version of his post here:
WTS Lancair 320/360 Carbon Backplate and Spinner
These are made of high temperature epoxy cured at 350 deg F and 150 psi. Precision milled bolt and hub pattern fits the Hartzell compact hub.
Light Weight Carbon Spinners also available.
(includes section to back fill behind blades)
You might contact him if you have not done so. I have also suffered issues of cracking with aluminum spinners. Zero issues for me since going composite.
Lancair 235/340
RV-9A (2013 - 2016)
11-04-2018, 04:58 PM
Chris z
Thank you so much! I sent Chris a pm but I know he is not too active here and it was only hours ago. Thanks again...hopefully we will get this fixed.
carl
Carl Bridges
RV7 N278RV
NOW FLYING
11-04-2018, 05:30 PM
Carl
Thousands of RV's flying without this issue, I would suggest you look for the root cause of the problem rather than looking for a band aid fix to mask the the issue.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
11-04-2018, 05:43 PM
possible problem fixed
Thank you Walt very true statement and good advice.
I believe the problem which led to two failures was the blade to spinner clearance was not adequate causing the spinner to wobble putting stress on the backplate. Since then the blade to spinner was opened up which I believe solved my problem but the damage was already done.
Carl Bridges
RV7 N278RV
NOW FLYING
11-04-2018, 05:46 PM
You should definately inspect the prop shank for damage, Hartzell allows zero damage in the blade root area.
If you're certain this was the issue than by far the simplest repair would to be make and install a new spinner and mount.
11-04-2018, 05:49 PM
no loosing of screws or bolts.
IO-360-a1b6. Had a little vibration 2400 20-24". Since the clearance increased no vibration. Vans spinner with forward and aft bulkheads aft having a doubler. Nuts not bottomed out, plenty of threads showing. Luckily no damage in the blade root area. when I clearance the spinner I called hartzell about the problem and they gave me a template which I recommend to all.
Carl Bridges
RV7 N278RV
NOW FLYING
Reason: more info
11-04-2018, 10:47 PM
I'd look at two things right off: proper deburring of the holes in the backplate to eliminate stress risers, and torque on the bolts/nuts.
2019 Dues paid!
11-05-2018, 05:13 AM
I had my back late crack recently and after looking at what was the root cause and allowing the backplate to flex, I discovered there were no screws in the front bulkhead. I cut out a new piece and riveted it in, along with adding fasteners to the front bulkhead and haven?t seen any further issues. I?m with Walt in that there?s thousands of these setups, what makes yours/mine so special when these issues are otherwise unheard of?
Shane
RV-6 IO-360 Angle valve, G3X touch
Murphy Moose M14P flying
Aero Engineer, A&P
