Old 10-14-2018, 01:00 PM
Piplnr65656 Piplnr65656 is offline
Default Fuselage quick build items to Delete
Hi, We are ready to order our fuselage quick build kit. Wanted to double check which items may be a good idea to delete from the kit and go aftermarket. So far we were thinking:
1. Windows, delete factory and use Cee Bailey.
2. Fuel valve, delete factory and use Andair. Is this still the best route to go?
3. Fuel and brake lines. We figured we should upgrade to the stainless steel braided lines but we are not 100% sure which items to delete from the kit.
Any other items we should consider changing out?
RV-10 N203DT empennage in process, fuselage on order.
Old 10-14-2018, 01:54 PM
Default And
Brakes, wheels, tires, cowl, spinner
ADD
VA-186 oil cooler mount
Baffle kit
VA-187 4? SCAT flange for baffle kit because it?s not included
Bob
Aerospace Engineer '88
RV-10
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
297 HP Barrett Hung
Wiring...
Dues+ Paid 2019,...Thanks DR+
Old 10-14-2018, 06:47 PM
mciaglia mciaglia is offline
I think rocketman is referencing the fishing kit...that?s where the cowl, spinner and wheels are
I deleted all the rudder pedal assembly as I installed the control approach pedals
Defiantly the windows if your planning CeeBaileys
There is a complete list of items deleted on my blog
Dr. Mark Ciaglia
The Woodlands, TX
Donating Monthly since 10/17
N189PT- Christen Eagle II
N627DG (reserved)- RV10 in the making
www.marksfamilyrv10.wordpress.com
Old 10-18-2018, 11:18 AM
Aircraft Specialty Aircraft Specialty is offline
Disregard...PM sent to OP
Steve Tschurwald- Aircraft Specialty LLC (Your source for Custom Parts for Experimental Aircraft), AS FLIGHTLINES (Joint Venture with TS Flightlines)
aircraftspecialty@gmail.com
www.aircraftspecialty.com
www.asflightlines.com
