09-24-2018, 12:48 PM
Step bolt access
We have a wee bit of play on our left step and I believe this may ba a common issue.
How do people access the bolt to replace or bush on a completed aeroplane?
09-24-2018, 02:02 PM
I intentionally cut 3/4" or thereabouts holes in the floorboards and belly of the airplane in anticipation of this issue. Snap plugs close the holes and my trusted factory resource saw no challenge with that approach.
Should be an easy mod to retrofit if you can get measurements for where to drill. I'd measure mine, but am out of town for a few days.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
09-24-2018, 03:49 PM
Thanks Kyle that sounds a very sensible approach. Sadly, I am guessing that here in the UK that would require a modification approval from our regulator, the Light Aircraft Association?
However it may be an option?
09-24-2018, 03:57 PM
Not that I'm a big rule breaker, but that one wouldn't exactly jump out at most inspectors.
Where are you in England, out of curiosity? I'm posting from London right now.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
09-24-2018, 05:00 PM
It?s actually described in the instructions as a way for access. So you might not need any additional inspections.
Dr. Mark Ciaglia
The Woodlands, TX
Donating Monthly since 10/17
N189PT- Christen Eagle II
N627DG (reserved)- RV10 in the making
www.marksfamilyrv10.wordpress.com
09-26-2018, 07:43 PM
step wobble
I'm about to install my floor panels and heard about this happening. I ordered (and received quickly) 2 "step bushings" from TCW Technologies. A friend of mine installed them and says they're great. He also installed an access panel in the floor and a small hole under the fuselage, to access later if needed to tighten. I plan to do the same.
Scott Calkins
Building RV-10
Working on overhead console and center console
Dues happily paid 2019
09-27-2018, 03:33 AM
Floor Panel
I added a small floor panel over the bolt.
It gives access for install/tightening of the step bolts as well as the com antenna installed in the same left and right bays.
Building started Oct 5th 2014, Flying since 1/16/2020
http://www.mykitlog.com/leok
RV Hotel, come by and visit if you're in town
Dues paid 2020
09-27-2018, 11:31 AM
I did the same with a opening large enough to get both wrenches in there. I used quite a few CS pull rivets, so it should easily hold the loads placed on the floor with cargo.
Larry
09-28-2018, 11:12 PM
inspection panel parts VA-195C/D
I used one inspection panel supplied in the kit since I did not install the wing stall-warning indicator. They are cheap and easy to install in the baggage area with lots of room for wrenches, and can all be done with solid rivets and squeezer (nothing against CS rivets, but solid if I can). Also is great access to the area for wiring too, like an ELT antenna or......... Always good just in case you do need to do something in that area, great your looking ahead!
Cheers, Mike
Michael Wright
Dues paid 2020
RV7 slow build, 500 h in the air: sold
RV10 slow build, ~300 h in the air: sold
RV7 started in 2020
09-28-2018, 11:25 PM
Cheers, Mike
I figure the Engineering is solid. The whole baggage floor is held on with pull rivets, so I assumed they were adequate for the load back there.
Larry
