I'm with Joe on the Peltor. I also modified a set with the ANR kit, which worked great, but I realize you want a passive headset.
Don't hold your nose against a cheap Flightcom headset.
Those things are just about bulletproof, I keep them as reserve headsets, and use them frequently.
Also, on any headset, you can bend the head band spring to change the tension, add padding across the top, put more or different stuffing in the ear cups or wear ear plugs inside.
Scott Emery
http://gallery.eaa326.org/v/members/semery/
EAA 668340, chapter 326 & IAC chapter 67
RV-8 N89SE first flight 12/26/2013
Yak55M, and the wife has an RV-4
There is nothing-absolute nothing-half so much worth doing as simply messing around with Aeroplanes
(with apologies to Ratty)
2019
