  #11
Old 09-16-2018, 02:44 PM
cderk's Avatar
cderk cderk is offline
Correct... VS is not an issue because it?s not attached. Height to top of fuse is the issue.
RV10
http://n688cd.wordpress.com
Old 09-16-2018, 03:32 PM
My fuselage (engine mounted, air in the tires) sits about 78" high. I would think letting a little air out of the tires and the appropriate amount of cussing would get it through a 77" high opening.
I think I'd rather mount the gear now and deal with extracting the airplane later than try to mount the gear after the 400 lb engine is attached. Heavy expensive things scare me a bit.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 09-16-2018, 03:52 PM
cderk's Avatar
I completely agree, Kyle. And that?s with your cabin top on?
RV10
Old 09-18-2018, 10:03 AM
ppilotmike's Avatar
Anybody know the max width at the wheels/tires, without the pants on? I think I'll be okay with head height, but I've got skinny garage doors..
Mike Rettig
VAF Dues Current
Old 09-18-2018, 10:05 AM
Yes, the top is attached.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 09-18-2018, 04:11 PM
Mike, mine measures right at 95" from the outside of one tire to the outside of the other. Because of camber issues, the max dimension (again 95") is near the top.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 09-18-2018, 04:15 PM
ppilotmike's Avatar
Thanks Kyle!
Mike Rettig
VAF Dues Current
Old 09-19-2018, 08:21 PM
Cbull's Avatar
Cbull Cbull is offline
You might take a second look at your garage door. Sometimes the opener stops the door from opening the full height of the actual opening. Measure the opening and see if it will clear. Then all you need to do is pull the safety latch on the garage door and push it up more than the opener would allow. Ask me how I know this, lol.
Cory Bull
Lakeway, TX
RV-10 , Interior done, Engine and avionics remain.
Planning on (3)10" Dynon HDX, Garmin GTN 650 and PS Engineering Audio.
2017 Dues Happily Paid
Old 09-19-2018, 08:56 PM
rongawer rongawer is offline
Default Wait a second...
Ok, I just assumed we?d already thought about deflating the tires. But maybe I?m missing something here.
Knowing the tires are 15? tall with a 6? wheel. That leaves a little over 4? of sidewall height to be deflated. If the top of the cabin is 80? and the garage door is 77?, just flatten the tires, drag it out the door clear of the cabin, and reinflate the tires.
Ron Gawer
- RV10, Build in progress.
- RV12, N975G, "The Commuter"...many great hours and happy landings so far.
- Several others that are now just great memories for me.
Old 09-19-2018, 11:40 PM
RV10Pilot RV10Pilot is offline
I measured the width of my RV10 and I got 95.25" wide from wheel to wheel, not including the axel extension.
I also measured the height. The engine is hung and my tires are very low on air and I got 76.75 inches, I have 4.5 inches from the ground to the bottom of the main gear axel.
It will be a very tight fit but it will fit. It will be so close that you won't know your exact dimensions until after you have the engine on your build. For mine a little more air out of the tires and I would have an 1" clear. A dolly for the axels would lower it 2" or so.
