Go Back   VAF Forums > Model Specific > RV-3
Old 09-17-2018, 01:02 PM
N329JR's Avatar
N329JR N329JR is offline
Default RV-3 Instr. Panel - Solid Works model or STEP ???
Does anyone have a STEP file or Solid Works model of the instrument panel for the RV-3?
Ian
RV-3B My RV
RV-6 (Dad's RV)
RV-8 Empennage 95%, Wings 95%, Fuse 2%
2020 VAF Gladly Paid
Old 09-17-2018, 01:58 PM
RWoodard's Avatar
RWoodard RWoodard is offline
I?ll be following this thread.
I?d like to install a new panel in my new-to-me RV-3 this winter.
I?ve asked my smarty pants Aerospace Engineering niece to draw it up for me in AutoCAD and/or Solidworks, but it hasn?t happened so far.
I?ll definitely share if I end up with the file.
Rod Woodard
Brighton, Colorado (CO12)
RV-3 N87CT (Thanks Chuck!)
Glasair 1RG N388DM
RV-3 N99RV sold 01/2000
F1 MkIII empennage?arrived 08/22/2018--collecting dust
Old 09-17-2018, 06:22 PM
Before using, verify that it fits your fuselage. The panel outline in the plans, for example, isn't as wide as my fuselage.
Also, do you want the panel to go to the external side skins or is it inset to allow the removable cover between the panel and firewall to sit flush to the sides? By the plans, the panel should be flush to the side skins but I've seen at least one that had that cover flush and the panel inset.
More, some panels have a slight bit of extra height over what the plans say. Usually, that's below where the plans have it but it might not be.
Be careful here.... this is an RV-3, and they often differ from one another.
Dave
