  #11
Old 04-29-2018, 08:44 PM
Steve Melton's Avatar
Originally Posted by RV6_flyer View Post
IF the plugs were in my hangar, I would use a spark plug erosion gauge to see if they are still in mechanical spec as well as do a resistance check.
purchased one of these. thx, I was not aware of them.
Steve Melton
Cincinnati, OH
www.rvplasticparts.com
Old 09-10-2018, 03:15 PM
Default 700 hr spark plugs
replaced all but one of them. 700 hrs was running fine but time to change. one had been dropped and replaced earlier, #3 down.
Steve Melton
Cincinnati, OH
Old 09-10-2018, 03:18 PM
Robb Robb is offline
I have 1200 hrs on fine wires wouldn't run anything else with magneto ignition
Old 09-10-2018, 09:38 PM
Kellym Kellym is offline
Quite frankly, I have run fine wires, and have had more trouble with them, at least in the Champion brand than with massives. Most eventually failed resistance test badly, going over 100K ohms. One recently removed failed in flight test, while okay on resistance and appearance.
Usually have trouble with intermittent misfire with older fine wires.
The other issue is that they are fragile to adjust gap, and waste a lot of money if one is dropped. To compete economically with massives you have to manage a full 2000 hours on a fine wire.
GAMI issued a service bulletin strongly recommending against fine wires of the C brand in a turbo normalized or turbocharged engine, where electrode ceramic failure was common.
Kelly McMullen
A&P/IA
EAA Tech Counselor
KCHD
RV-10 40866
Old 09-11-2018, 02:43 PM
TimO TimO is offline
Kelly,
I've heard that Champions fine wire plugs are more of a "stay away" product. I've been running fine wires in my -10 for well over 1,000 hours with no issues, and nearing 300 on the -14. But, mine were Autolite/Tempest. I treat them very well when I pull them though because as you mention, dropping one is an expensive lesson.
Tim Olson - CFI
RV-10 N104CD - Flying 2/2006 - 1400+ hours http://www.MyRV10.com
RV-14 N14YT - Flying 6/2016 - 350+ hours http://www.MyRV14.com
Old 09-11-2018, 07:14 PM
what is this "pull them thru method"? I told myself I would never drop one, but I did.
Steve Melton
Cincinnati, OH
Old 09-11-2018, 11:38 PM
Default There?s no ?r?
?...when I pull them, though, ...?
Old 09-12-2018, 04:31 AM
N804RV's Avatar
N804RV N804RV is offline
I’ve been annealing spark plug washers with a propane torch and some tap water in my last empty Starbucks coffee cup for awhile now. Just torch ‘em till they glow orange. Then quench in water and burnish with scotchbrite when cooled.
Ken W.
Mount Vernon, WA
2020 VAF Supporter
Old 09-12-2018, 04:45 AM
snopercod's Avatar
I guess I'm getting lazy in my old age because for 30c each, I just buy new ones (I have a box of 100).
(2020 dues paid)
Old 09-13-2018, 05:06 PM
that equals 3000c.
Steve Melton
Cincinnati, OH
