Old 09-11-2018, 02:17 PM
ZachMiller ZachMiller is offline
I quoted renting a truck to drive a kit from Oregon to Texas and it was around $1000 and over 20 hours. Not worth it in my opinion.
Also, I'm in Caddo Mills building an RV-7. Probably an hour from Tyler. I'm planning on flying there for lunch this weekend, actually.
Zach Miller
RV-7 Empennage Complete, Wings Underway
Donation made 2020
Old 09-11-2018, 04:58 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Originally Posted by Bavafa View Post
One other idea would be just to rent a one way U-Haul and take it yourself. You get to see the country side and might save a few $$$. This is what I did, though my distance is not nearly as far as yours and it worked great. I got all the kits, including finishing kit and did not need any crating which saved $$$ .
This might work out for some, but when you count the rental, the gas, and time to drive it yourself (including one way transportation to get in position) the percentage saved is small. I have a kit coming from Wisconsin later this month, and I did the math - far easier to let Tony do it. Maybe a few dollars more - but I?d spend those buying material to build support structures in the rental to make sure nothing shifted on the way....
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
