Old 09-05-2018, 07:18 PM
Tbone's Avatar
Tbone Tbone is offline
Default Garmin GTX 327 power
I?m working on a transponder install (GTX 327). I have connected the power wire to CB, the Avionics wire to a switched power. When I power up the aircraft the transponder is off. Good. When I power the Avionics master up the transponder powers up. Good. Now when I turn off the Avionics master switch off the transponder stays on. Not what I expected. Can someone tell me what is the purpose of the master avi wire going into the transponder is for? My thoughts were that the Avionics master would (should) turn the transponder on AND off. No? It it just a ?sense?wire?
___________
Terry
RV7
XP IO360
Old 09-05-2018, 07:22 PM
bobnoffs bobnoffs is offline
i think that it tells the transponder to power up every time the master is turned on vs. waiting for the on button on the transponder to be pushed.
Bob Noffs
n. wi.
dakota hawk/jab 3300 built and flying. sold 6/18.getting serious about the 12. in the hangar now as of 10/15/19
RV-12 kit as of 9/13
Old 09-05-2018, 08:04 PM
Tbone's Avatar
Yes it turns it on but when I turn avi master switch off is still stays on! Is that how it’s designed?
___________
Terry
RV7
XP IO360
Old 09-05-2018, 08:15 PM
g3xpert's Avatar
g3xpert g3xpert is offline
Default GTX 327 Power up
This is as designed behavior. The following note is from the installation manual:
"Avionics Master On, when tied to 11-33 VDC input provides automatic unit power up. When power is applied the unit will power up in the last mode selected."
If you want the unit to power down when you turn off the avionics bus, you could move the circuit breaker from the main bus to the avionics bus.
Levi
Garmin G3X Support
g3xpert@garmin.com
Old 09-05-2018, 08:25 PM
Tbone's Avatar
Default Thanks!
Thank you Levi ! I thought I was going crazy. So the avi master wire is just a trigger wire to turn it on but not off? Understood.
___________
Terry
RV7
XP IO360
Old 09-08-2018, 11:35 AM
Geico266's Avatar
Geico266 Geico266 is offline
How do we set the GTX327 to turn on automatically with the avionics master?
RV-7 : In the hangar
RV-10 : In the hangar
RV-12 : Built and sold
Old 09-08-2018, 02:51 PM
g3xpert's Avatar
Post
Hello Larry,
Just connect the avionics master power to both pins 1 (avionics master on) and 15 (input power).
Whenever the avionics master switch is turned on, power will be applied to both pins and the GTX 327 will power up automatically without pressing any buttons.
Steve
Garmin G3X Support
g3xpert@garmin.com
