Old 08-31-2018, 09:53 AM
RicoB RicoB is offline
Default RV9a glide ratio ?
Just trying to figure out the glide ratio to put in the for Foreflight ser up. It?s a
RV9a, O320, electric MT constant speed
Rico Burgos
2018- RV9a at KWHP
1959- C-150 at KMOD
https://www.imdb.com/name/nm3018529
Old 08-31-2018, 10:00 AM
Dale D's Avatar
Dale D Dale D is offline
Default CAFE Reported 12 : 1
Rico,
The RV-9A CAFE report listed the following:
"Best glide ratio, idle power, coarse pitch, 1738 lb, 95 mph CAS
12 to 1"
YGMV (Your Glide May Vary).
Regards,
Dale
Dale DeWeese
RV-9A Owner
EAA Chapter 211 Member
Zeeland, MI (Z98)
VAF Dues Paid
Old 08-31-2018, 10:04 AM
YellowJacket RV9 YellowJacket RV9 is offline
Especially with your less common prop, there is only way to know for your specific setup, which is to do some testing. I have seen a very wide range of reported glide speeds for 9's. Ratios may be similar, but I assume you'd still want to know what speed to get that ratio.
Chris
Chris Johnson
Old 08-31-2018, 10:14 AM
flyboy1963's Avatar
Default more than one?
....this from a guy who has done NO flight testing....
is there more than one?
can the MT fail in coarse, and fine pitch?
I would think you want best ratio, meaning DISTANCE....
and also minimum SINK, where distance is not as important as time aloft.
( ok, I am hard pressed to think of an emergency where you are above an airfield, and want more time aloft!)
Perry Y.
RV-9a - SOLD!....
Lake Country, BC
Old 08-31-2018, 10:35 AM
I will do some specific flight test on that matter but for the moment I?m tryin to get the basics of my Foreflight filled out. If I start with an average number it?s agreat start.
If the electric mt prop fails it will stay at the current pitch.
Rico Burgos
2018- RV9a at KWHP
1959- C-150 at KMOD
