08-21-2018, 02:23 PM
Forum Peruser
Originally Posted by Ed_Wischmeyer
...I checked a bunch of C712 panel pictures with google, and some of the simulators had the flap switch on the left of the power controls, possibly to save space, but all the airplanes had the flap switch on the right...
Did you intend C172??
Don Hull
RV-7 Wings
KDCU Pryor Field
Pilots'n Paws Pilot
08-22-2018, 10:02 AM
In the same way that it doesn't make sense to build a custom motorcycle and change swap the controls around and how they operate, it doesn't make sense to "innovate" on switch location -- someday, somebody is going to fly a non-standard airplane and be confused and maybe use the wrong switch, or somebody who is used to this airplane will fly a different airpane and maybe use the wrong switch.
Flaps go on the right of the power controls, or in the center, according to FAR23.777:
(f) Wing flap and auxiliary lift device controls must be located?
(1) Centrally, or to the right of the pedestal or powerplant throttle control centerline;
Interesting. Most bonanzas have a flap on the left, gear on the right. Of course, a lot of inadvertent gear ups have happened because of this. Maybe they are certified under the CAR rules but pretty sure there's FAR 23 bonanzas with the flap on the left.
For what it's worth, I'd prefer everything to be standard too.
RV-9A finshed! For sale
08-29-2018, 06:53 AM
Updated panel
Updated my blog based on all the great feedback thus far. Looking forward to continuing to refine and have now engaged UpNorthAviation to help finalize the layout. Love to hear feedback on the panel. I also am installing my gear switch just to the left of the throttle. I think it?ll be best there.
Here?s a recent photo arriving into Oshkosh.
Lol. Ok, it?s not a retract, but it sure looks cool. Hahahaha.
Cheers, Josh
Searching for a RV6 / 6A flying or project
N67LJ RV9-A - SOLD
N83LJ Sonex - SOLD
rvpilotlife.wordpress.com
'20 supported!
08-29-2018, 07:43 AM
A consideration is putting the carb heat where the alternate air knob is. In a go around situation you could just stick you thumb out and hit throttle and carb heat. Of course you can use the palm of your hand and fingers extended and probably get the throttle, mixture, and carb heat with one motion the way you have it now. You may never use the alternate air.
Maxwell Duke
Kitfox S6/TD/IO240/SteamIFR Built it
RV10 IO540/AFS5600x3 Bought it
CH750 O200/AFS5500. Built it with 7 friends. DAR-Vic Syracuse
Maule M7-235C Sold it(kind of miss it)
VAF paid 5/2017
08-29-2018, 01:16 PM
I'm not sure if you have considered the support structure that is required behind the panel. The radio stack requires some angle pieces to mount those racks. I'm not sure if you have allowed for those pieces in your layout. It doesn't seem like you have. If you look at the other pics folks have posted you see a gap between the radio stack and the adjacent units.
Ray Tonks
2020 Donation Paid
Titan IOX-370, Dual PMAGs, 9.6:1 Pistons, FM-150
RV-7 Fuselage in progress
* Cabin Interior - In progress
RV-7 SB Wings
* Both Wings fully skinned
* Fuel Tanks Complete - No leaks finally
* Ailerons Complete
* Flaps Complete
RV-7 Empennage - Complete (a little fiberglass work left)
Vans Training Kit # 2 - Complete
RV-7 Preview Plans
Vans Training Kit #1 - Complete
EAA Sheet Metal Class - Complete
08-29-2018, 02:56 PM
Yeah, the exact spacing I?m going to let UpNorth manage as he does the official design plan in CAD. I suspect all of my items will move slightly, a another example being the fuses. Thanks!
Cheers, Josh
N67LJ RV9-A - SOLD
N83LJ Sonex - SOLD
'20 supported!
08-30-2018, 06:43 AM
On RVs, carb heat and alternate are the same thing. You only need one knob, and the preferred location is to the left of the throttle.
You might want to check your circuit breaker spacing. They take up space behind the panel and the CBs I'm familiar with probably wouldn't fit in the space you've allocated. And in the same way that it makes sense to group and outline switches, do that for circuit breakers.
I'm not familiar with how Dynon systems do updates, but on my plane, I wish I had a way to power up just the avionics having database updated rather than running the battery down with everything on or without pulling a bunch of circuit breakers.
Ed
RV-9A at KSAV (Savannah, GA; dual G3X Touch with autopilot, GTN650, GTX330ES, GDL52 ADSB-In)
Previously RV-4, RV-8, RV-8A, AirCam, Cessna 175
ATP CFII PhD, so I have no excuses when I screw up
2020 dues slightly overpaid
Retired - "They used to pay me to be good, now I'm good for nothing."
08-30-2018, 07:07 AM
Alternate Air (Filtered Airbox Bypass) is not the same thing as carb heat. Filtered Airbox Bypass is a separate control for use in case of intake filter blockage. https://www.vansaircraft.com/pdf/Fab-sb_05.pdf
It doesn't take a lot of snow to clog the FAB pleats and starve the engine of induction air. I know of two RV fatalities and a forced landing resulting from this.
It is a great idea to install the FAB Bypass that Van's provides (in addition to the carb heat control).
Tim Lewis
CFI, A&P
RV-10 N31TD - 1250 hrs
RV-6A N47TD - 1100 hrs (sold)
08-30-2018, 09:11 AM
Thanks, I learned something new! Now I?ve got some reading to do.
08-30-2018, 10:54 AM
Originally Posted by jjbardell
Here’s a recent photo arriving into Oshkosh.
Lol. Ok, it’s not a retract, but it sure looks cool. Hahahaha.
I can't believe you would leave those "GodAwfull" steps hanging out in the breeze! Gotta cost you at least 0.2 kts.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
