Flightstream 510
I believe that unless you're using the G3X Touch, you'll need the Flightstream to enable bluetooth communication to the GTN. I have a legacy G3X setup that doesn't have bluetooth capability and so use the Flightstream 510 to connect the iPad with the GTN. The GTN then shares the info with the rest of the EFIS system. If you're running Garmin Pilot on the iPad, then you get wireless database updates to the GTN as well. I'm using Foreflight, so I'm stuck with manual updates. If you decide you're in the market for Flightstream 510 - I'll sell mine for $950.
RV-10 N415JS
Slow build kit #40874
Homebuilt Kit Champion Oshkosh 2019
Atlantic crossings: 2
