Old 08-18-2018, 01:31 PM
Ed_Wischmeyer's Avatar
Ed_Wischmeyer Ed_Wischmeyer is offline
Default Pneumatic squeezer problem
So I?m using my pneumatic rivet squeezer for the first time in maybe 15 years (!). The ram, fully retracted, extends 0.3?, and fully extended, the gap (with no set installed) is 0.4?. I took the yoke off and the ram out, and it?s a fixed ram (non-adjustable). So I?m wondering if the squeezer has something wrong inside causing the ram to be too far extended, all the time? Hopefully I?m doing something dumb that I just don?t remember.
There is no manufacturer or model number on the squeezer body. And I do have a full bunch of flat sets of various thickness.
I?ve looked briefly at the Cleaveland too youtube video, and although that reminded me of some things I?d forgotten, it didn?t help solve my problem.
So is there something internal that needs to be looked at? I'm not looking forward to taking it apart but can surely do that. And there are no indications of rust or sticking.
Thanks!
RV-9A at KSAV (Savannah, GA; dual G3X Touch with autopilot, GTN650, GTX330ES, GDL52 ADSB-In)
Previously RV-4, RV-8, RV-8A, AirCam, Cessna 175
ATP CFII PhD, so I have no excuses when I screw up
2020 dues slightly overpaid
Retired - "They used to pay me to be good, now I'm good for nothing."
Old 08-19-2018, 07:35 AM
ZachMiller ZachMiller is offline
It doesn't have a button that limits the retract stroke, does it? One of mine (I have a tool buying problem) has a button just beneath the yoke that stops the ram from retracting all the way. I guess the idea is that it would be quicker to actuate but when it's engaged the gap is generally too small to get over an unsqueezed rivet, making it useless.
Post a picture if you can.
Zach Miller
RV-7 Empennage Complete, Wings Underway
Donation made 2020
Old 08-19-2018, 02:46 PM
Default Found the problem
I had a longeron yoke installed in the squeezer, and although it has the same gap as the plain yoke, the base is not as tall, causing the ram to protrude into the gap. When I put the "standard" yoke in, the problem went away.
I guess the longeron yoke is designed for a shorter ram, and I'd either not noticed it before or had forgotten it.
Old 08-19-2018, 03:08 PM
While it's not helpful yet, once you get the squeezer operable, get an adjustable ram. Makes gap setting much faster.
Dave
Old 08-19-2018, 07:49 PM
I had an appropriate length ram hidden in a tool drawer. Like I said, I'd not used it in 15 years...
