Old 08-18-2018, 09:10 AM
bayoubengal bayoubengal is offline
Default Need Cradle Plans
Does anybody have cradle plans for wings, VS, HS and rudder they?d be willing to share? Much appreciated...
Hutch
David W. Hutchinson
NAAA/PAAO Certified Aircraft Appraiser (Nationwide)
Perry, GA.
RV-10/N433DH (Res)
www.TwoEaglesAviation.com
Old 08-18-2018, 09:51 AM
KatanaPilot KatanaPilot is offline
Default Here's one for the wings
Enjoyed meeting you this week Hutch. Here are plans for a wing cradle very similar to what you saw in the hangar.
https://goo.gl/images/DM17yd
Krea Ellis
Locust Grove, GA
DA20-A1 "Princess Amelia" - gone home to Amelia Island
RV-7A Phase 2
RV-10 under construction at Synergy Air South
Old 08-18-2018, 10:14 AM
AdamB AdamB is offline
Mouser has all the wood length measurements and some pictures of assembly, which I referred to when I built my wing cradle here:
http://mouser.org/projects/rv-10/wingassembly.html
RV10 - #41687
http://adamsrv10.wordpress.com
N56AB Reserved
Old 08-18-2018, 10:20 AM
For the HS, you should be able to re-use the cradles that are made as part of the HS construction process in section 8.
RV10 - #41687
N56AB Reserved
Old 08-18-2018, 08:10 PM
Bill Boyd's Avatar
Bill Boyd Bill Boyd is offline
Default Getting up on gear
How tall does the support structure under the fuselage need to be to allow drilling the gear legs and mounting the wheels? I'm looking at taking the project off the gurney and standing her on gear in the next couple months and realize I'll need to lift it quite a ways above the height it's resting at now.
Bill Boyd
Hop-Along Aerodrome (12VA)
RV-6A - N30YD - Built '98 / sold '20
RV-10 - N130YD reserved - under construction
donating monthly to the VAF - thanks, Doug
Old 08-18-2018, 08:30 PM
An engine hoist around the engine mount works. I wouldn't try it with the engine mounted. Alternately, if you have something strong overhead, a come-along and a couple of lifting straps around the engine mount could do it. Obviously, you don't want to lift from the middle of a tube, and you probably want to have the tail resting on a sawhorse.
That said, sitting on the gear, engine mounted, no wings, the bottom of the spar on my airplane is at 27.5" off the ground. I think you'd want another foot of height, maybe just less than that, to mount the gear.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 08-19-2018, 02:55 PM
RV10Pilot RV10Pilot is offline
That's my wing stand, but I am sure I stole the design from someone else. LOL. Unfortunately that have been holding my wings for something like 15 years. I am a very slow builder. Fortunately the stand works well.
Larry
