Old 08-07-2018, 01:08 PM
Vic LaRocca Vic LaRocca is offline
Danny, Looks like it kicked out again. -Vic
Old 08-07-2018, 03:35 PM
roadrunner20's Avatar
roadrunner20 roadrunner20 is offline
This time, I sent it to you as a zip file, but through my own smtp server vs gmail.
Sent to me also, I received the file in my non-gmail acount & was able to unzip.
My gmail account blocked it inbound & outbound
Danny "RoadRunner" Landry
Morphed RV7(formally 7A), N20DL, PnP Pilot
1190+ hours
2019 Donation Paid
Old 08-07-2018, 04:36 PM
Got it and it unzipped ok. Will let you know how it goes tomorrow PM. Thanks, Vic
Old 08-08-2018, 04:39 PM
Worked fine. Thanks Danny. -Vic
Old 08-10-2018, 07:59 PM
Feder Feder is offline
Default NavWorx EFB Tablet
I have completed initial testing and have found that the Android based EFB iFlyGPS and AVARE both work with my ADS600B. Both programs need the WiFi since they do not work with Bluetooth. iFlyGPS program loads onto and receives signal from the NavWorx directly. The I/O Plug-in of the AVARE is needed to transmit nmea data from the NavWorx to the Tablet and must be using code 4000. Both EFBs need to have NavWorx Transmit baud rate 115,200 set on Traffic Alerts.
Old 08-10-2018, 08:36 PM
That's great
I'm happy to hear it worked for you.
1190+ hours
2019 Donation Paid
Old 12-29-2018, 07:22 AM
dvalle dvalle is offline
Default Navworx installs
I see this is old....
I've been installing these units helping those stuck with them by as a low cost ADSB install. Looks like on the latest install, I'm having trouble like described here...for me, a baro failure. The detailed report shows intermittent. Like you, I have replaced almost everything. 3 encoders (not trusting the second one), a transponder and today I plan to try a diff Navworx units. All checks come up good on the programming. Any more help would be appreciated.
Old 12-29-2018, 08:25 AM
rleffler's Avatar
rleffler rleffler is offline
I would check the obvious, a loose wiring connection or chafing wire. Put an ohm meter to test continuity and wiggle the wire at various places along the route.
Is this a 600 or EXP?
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 01-02-2019, 02:13 PM
As mentioned earlier, I've been working with others stuck with these units (including myself) because of the AD by selling and installing (per AMOC) at a significant savings over all other ADS-B units. So far good luck except one plane...an RV6A. The plane keeps giving Baro Alt failures. I am pulling my hair out trying everything and still no luck. Changed encoder, transponder, transmon, Navworx unit, checked wiring...no luck. Sure learned a lot in the mean time on how this unit and ASD-B work. Any ideas??
Old 01-03-2019, 05:51 AM
rleffler's Avatar
Easy to debug, since just about all inputs to the 600 are ascii text strings. Just use hyperterminal or putty to watch what data is being transmitted on the encoder line. If you see data, the problem is the Navworx box or configuration.
No data, then the problem is the encoder or an open circuit.
Bob Leffler
